Battery Tender Junior Question...
(Note: the comments below were also present when I was using the alligator clips and not hard wired).
-The steady RED light is supposed to turn GREEN when the battery is fully charged. Despite charging all night/day, I've never seen the GREEN come on. Always steady RED. (I know the battery is fully charged since on one occasion, I parked the car after a two hour day-time run for all night charging in the garage).
-The Battery Tender Junior seems quite hot. Much hotter than "warm".
Any thoughts on both?
Thanks, Bob/Bradenton
Has the hot to the touch, just checked mine, and would say it's very warm but not hot.
Hope it helps, you might have bad unit.
Regarding the high temperature I mentioned, I just measured it and it was 125 F right at the plug-in blades and about 105 in other areas. Not as hot as it felt.
Thanks for the comments, as always.
Bob/Bradenton
PS: Since the car is in a tight garage with no access to the battery side of the car, and I couldn't use the alligator clips due to the location, I cut off the stock ring terminals on the Tender and just used the stripped wire mushed between the battery lugs and the battery. The stock Tender rings have a too small diameter for the C5 battery lug bolts.
The Yellow Top is also used as a deep-cycle battery and I think that's why it takes longer for the green "charged" light to appear. The Junior only charges at the rate of .75A per hour. Their instruction booklet says it can take days to fully charge a deep-cycle battery.
When I don't attach my Tender Junior to my C5 for a few weeks, the red light stays on for a day or so then I get the flashing red light for about 6 hours before it goes to a steady green. The C5 electrical system will always have a small current drain so it could take longer to charge a connected battery compared to a battery sitting on a bench.
