2000 C5 Manual transmission fluid help
Anyone done the same and had issues?
It's been the gearbox for four weeks now.
Amazon website, and Redline say it's ok to use😐
Amsoil synthetic ATF and Amsoil torque drive synthetic ATF are THE ONLY synthetic transmission fluids compatible with the pre-2001 m6 transmissions. It is the only synthetic ATF that has additives to counteract the swelling of cellulose compounds that occurs when they are exposed to synthetic ATF.
The cellulose components are the blocker rings (replaced with carbon fiber in 2001), and if you use anything but traditional petroleum based DexIII ATF or the above listed Amsoil fluids, you are ruining your transmission. Using the wrong fluid is not something you will notice until about a year or two after the fact, and it cannot be reversed without a rebuild.
Amsoil torque drive synthetic is the better of the 2 Amsoil fluids, and is hands down the absolute best fluid you can put in your pre-2001 m6 transmission. Personally, I would still use it in a 2001+ m6 or m12, and many people do.
Mr. Sam
Mr. Sam
Now mine was one of the very first '98's, built on Day 4 of the production run. So, it may have a pre Tremec (Warner built) 6 speed- I don't believe they sold that business to Tremec until 1998. Does it make any difference? Who knows.
Anyway, I have definitely issues with the "lasting damage" theory as my own experience directly contradicts that assertion.
