steering wheel position sensor ????
Old Oct 23, 2015 | 07:09 PM
gmbal4's Avatar
gmbal4
Default steering wheel position sensor ????
Got the check engine light on and ran a scan I was told wheel position sensor . Is it ok to drive the car with the sensor bad or should I just park it. was heading out of town until this happened ??
Old Oct 23, 2015 | 09:13 PM
Not having any problems with mine, but interested in the answer.
Old Oct 23, 2015 | 11:41 PM
SmokeEaterC5's Avatar
SmokeEaterC5
Cruising
Default steering wheel position sensor????
When I ran codes on my 99 one of them was an A6-SCM B2860. I looked the codes up. The SCM stands for Seat Control Module and the code translates to: Telescoping Column Position Sensor Failure Since my telescoping steering column adjuster doesn't work, I'm assuming that's what triggered my code. That's not the code you received, is it? If so, and your telescoping column adjuster isn't working, there's no issue driving it. I'm assuming it's tied in to the memory seat control settings.
If someone knows how to correct that problem and would like to chime in, that would be great.
Old Oct 24, 2015 | 06:50 AM
dadaroo's Avatar
dadaroo
Running a scan sounds like you went to a parts store instead of pulling your dash DIC codes. Auto stores only pull emission related codes.
If you have never pulled them there may be a lot of old ones. Pull them, record them, delete them, and then go for a drive. Pull them again before you turn the engine OFF. You may have to reset any DIC messages first to access the codes. Then Post the first set and then the ones after the drive. Include the module they are under and if they are H, C or H and C.
READING YOUR C5 Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
NOTE!!! Start the car and let it idle. Then take it for a drive and cause the problem to occur. When you return home pull the codes BEFORE you shut off the engine.
Do NOT discount the codes with the H following them. They can provide an audit trail for issues going on with the car. They ARE important in diagnosing problems.
Post ALL the codes that you pull with the engine running..........
Some codes go away WITHOUT setting an H code when you shut the engine off. I suspect you will have several codes that will show C or HC that do NOT show when the engine is turned off.
Mr. Sam
Old Oct 24, 2015 | 09:22 AM
Lazarus Long's Avatar
Lazarus Long
My 98 throws an intermittent C1281, which may be due to the swps. It doesn't set any lights, just 'service vehicle soon' in the DIC. I haven't noticed any adverse effects, so I've been ignoring it. It has been doing it since the car was new.
If the swps does die, I think I only lose the variable boost power steering. I don't have active handling.
Old Oct 24, 2015 | 10:05 AM
gmbal4's Avatar
gmbal4
well I cleared the codes and drove my car out of town on a long trip . Now I hope I did not screw anything up
Old Oct 24, 2015 | 10:12 AM
CactusCat's Avatar
CactusCat
Very unlikely that clearing your codes will "screw anything up". There can be a ton of reasons you'll have codes listed, some which could be totally unrelated to anything (like disconnecting your battery will throw a bunch of em). Clearing them allows you to see what is actually going on when any new codes return. GL w/your search.
Old Oct 24, 2015 | 01:10 PM
73Corvette's Avatar
73Corvette
even low voltage, bad connections, bad grounds, can cause all sorts of codes to party on Garth...
To steering wheel position sensor ????
