[Z06] Need help curing wheel hop
Old Oct 29, 2015 | 09:05 AM
grn envy's Avatar
grn envy
Cruise-In X Veteran
Default Need help curing wheel hop
My 04 Z has horrible wheel hop. Doesn't matter if from a stop or a rolling start. It hops through 1st and through 2nd. I'm running stock size tires on NT05's. Any advice or knowledge is appreciated.
Old Oct 29, 2015 | 10:07 AM
radar502's Avatar
radar502
Let off the gas .. Had to say that .. LOL... My 04 Z just spins no wheel hop ??? also running street tires .I'm sure people on here knows what to do about that ... after a retune on my 04 will be going to a set of Nittos 555Rs my self .. Mine may start hoping also with better traction ..??
Old Oct 29, 2015 | 11:10 AM
SaberD's Avatar
SaberD
does it hop as high as the pic in your sig? that's gotta be the most intense wheel hop I've seen!
On a more serious note, trans and motor mounts will help tremendously. so will poly control arm and sway bar bushings.
The problem with wheel hop is the suspension gets preloaded and then releases. All those rubber bushings and mounts allow so much movement that it basically acts like a spring. Stiffen them up and get rid of the ability for things to bind up, and you are on the right track to reducing wheel hop.
Old Oct 29, 2015 | 11:52 AM
grn envy's Avatar
grn envy
Cruise-In X Veteran
Would you recommend going to a stiffer shock, or at least adjustable?
Any good vendors on here for a new set of bushing?
Old Oct 29, 2015 | 01:31 PM
SaberD's Avatar
SaberD
I haven't installed a bushing kit yet, so I don't have advice for you there as far as brands go. If your pockets are really deep, go with delrin. Otherwise poly will be fine, but you will need to install zerk fittings in the control arms to be able to re-grease the bushings with poly.
As far as the shocks are concerned, the 2004 z06 has pretty much the best non-adjustable shocks that you can get for a c5.
Old Oct 29, 2015 | 01:40 PM
MX621's Avatar
MX621
I run stock size nt05 and get zero wheel hop. Sounds like u have to much pressure. The nt05 like to run on the low side. I usually run 29psi front, 27psi rear cold... Even on autocross/hpde events I'm under 30psi to start.
Old Oct 29, 2015 | 03:56 PM
StingrayRebel's Avatar
StingrayRebel
you have good tires so that probably isn't causing the hop... tire pressure could be a contributing factor but I would lean more towards replacing the motor and diff mounts with something more rigid like pfadt's stuff... mine hopped when it was stock but I changed tires and motor/diff mounts and the hop has disappeared
Old Oct 30, 2015 | 05:34 AM
Atok's Avatar
Atok
That's it. Our cars don't wheel hop, it's drivetrain shake. You get torque wrap in the drivetrain and sets of this nasty shake. Mine did it from new. Pfadt sells engine mounts and a transmission mount which apparently help. Although, I thought they were out of business... Maybe they are back.
http://store.afecontrol.com/afe-cont...-97-04-orange/
Old Oct 30, 2015 | 08:55 AM
grn envy's Avatar
grn envy
Cruise-In X Veteran
I do have a new trans mount in there. Was installed 6 months ago. Could it also be related to the active handling system? I plan to do some testing this weekend to try a few of the suggestions here.
Old Oct 30, 2015 | 09:09 AM
bjones7131's Avatar
bjones7131
I have 0 hop and I drove a friends 06z last Sat. and it had no hop, sorry can't help
Old Oct 30, 2015 | 09:39 AM
SaberD's Avatar
SaberD
definitely not related to the active handling system. Even brand new stock mounts will have the same problem. What you need to do is upgrade to urethane mounts from the stock rubber. I use the Hinson motorsports mounts, and they are great. They even make motor mounts that are 3/8" shorter than the stock mounts bringing down the CG height.
Old Oct 30, 2015 | 11:30 PM
bikeriderga's Avatar
bikeriderga
I had wheel hop when I was running Pireilli P-Zeros, same symptoms as what you are experiencing. Switched to Michelin Pilot Super Sports, problem solved.
Old Oct 31, 2015 | 12:08 AM
StingrayRebel
... personally I am not a fan of hinson's diff mount... it is better than stock I'm sure but I much prefer the design of the pfadt/hoosier mount since it runs the length of the cradle and applies pressure on both ends which keep the trans and diff from moving... be careful running the lower motor mounts if you ever decide to use an oversized balancer... I have seen guys have to clearance their cradle because the balancer was so close that it would either make contact or they didn't have enough room for the belt to fit between the cradle and balancer... weren't those mounts designed so the fast 102 would clear the cowl?... I'm not totally sure but I think I read that somewhere
nt05's are not crappy tires though... in my opinion he should start with the motor and diff mounts to keep the drivetrain stable
Old Oct 31, 2015 | 12:42 AM
LT1driver's Avatar
LT1driver
drive like and old lady will help
Old Oct 31, 2015 | 01:02 AM
StingrayRebel
but that's no fun!... if we wanted to drive slow we would have bought a convertible right?
Old Oct 31, 2015 | 10:10 AM
SaberD's Avatar
SaberD
Yeah the lower mounts were designed to allow a couple styles of intake manifolds to clear the cowl, but an added benefit is the lowered cg.
As far as the trans mounts go, I totally agree that the pfadt/hoosier mounts are far superior for reducing wheel hop, but they are also more than twice the cost. It also adds some weight while the hinson does not. The hinson one is a good buy for the money, and a good route if you are going for light weight.
Old Oct 31, 2015 | 11:29 AM
ezrider4u2's Avatar
ezrider4u2
A lot of good suggestions here, I would also suggest looking at a couple of other items before spending the $$ just in case- do a check of the suspension. I know you have an 04 but without knowing your usage and mileage it may be hard to pinpoint things. You described "wheel hop" but is it one side over the other? I would suggest checking things like the tie rods, and possible worn shocks, etc. These parts if worn can allow the suspension to act a certain way under acceleration.
Good luck to you.
To Need help curing wheel hop
Old Oct 31, 2015 | 11:50 AM
StingrayRebel
hmm, interesting about the weight... I just got rid of my pfadt mount since I can't use it on my tr6060 swap but it never felt heavy to me in hand... the box I shipped it in was 4lbs total so I'd say 3-3.5lbs of that was the mount... I have a stock diff mount in my garage, I'll have to weigh that in a bit... going off my memory the stock mount felt as heavy or maybe a tad heavier than the pfadt mount
Old Nov 1, 2015 | 07:21 AM
Atok's Avatar
Atok
Does anyone have a link to the Hinson mount?
Old Nov 1, 2015 | 07:43 AM
ezrider4u2's Avatar
ezrider4u2
Motor mounts
https://www.hinsonsupercars.com/p-12...vette-gto.aspx
Trans mount
https://www.hinsonsupercars.com/p-13...-corvette.aspx
