Led
Old Oct 31, 2015 | 09:35 PM
W5WTS's Avatar
W5WTS
6th Gear
Default Led
Can someone tell me where to find C5 Insturment cluster red Led bulbs and how many it takes to replace? Thanks in advance.
Old Nov 1, 2015 | 12:30 AM
zachaeous's Avatar
zachaeous
Default led
here is a link for a replacement kit:
http://www.pfyc.com/GN2035.html
you will have to check with them for proper fitment.
hope this helps.
Old Nov 1, 2015 | 12:58 AM
SilverC54me's Avatar
SilverC54me
What lights on the instrument cluster do you want to replace? If you are looking to change how the gauges are lit, these are done with blacklight UV tubes. You would have to change the gauges to change the color.
If it is the buttons on the sides, read the thread 'New Interior LED Mod Thread'. Follow this link for it, https://www.corvetteforum.com/forums...od-thread.html.
This thread has all of the information you could ever need to update the interior lighting to LED.
Gary
Old Nov 1, 2015 | 01:37 PM
huesmann's Avatar
huesmann
The idiot lights are replaceable, though. They're just Type 74 bulbs in screw sockets. However, you're likely to have to R&R the cluster several times since LEDs are polarity dependent, so your bulbs may not light, and you'll have to flip them 180º and try again.
Old Nov 1, 2015 | 04:13 PM
W5WTS's Avatar
W5WTS
6th Gear
Gary
Thanks Gary, I have changed the TIC and heads up lighting with led ,I was wondering about the whole instrument cluster, speedo, tach, fuel, etc, I think you answered my question. sounds expensive ,thanks....
Old Nov 1, 2015 | 04:20 PM
W5WTS's Avatar
W5WTS
6th Gear
hope this helps.
To Led
