Live in town-home community and basically everyone dislikes me because I wake them up every morning. Now moving next month to another complex and want to make friends with neighbors.
Setup..
ARH 1-7/8" headers with ARH x-pipe without cats and B&B Bullets.
Would replacing the Bullets with stock exhaust not cause the neighbors walls to rattle when started inside a garage? Or would I have to replace more?
Setup..
Any input will be helpful
+1 for Z06 Ti exhaust + cats if you felt inclined to do so. If those are hard to come by and you don't mind doing some cutting and a little welding, C6 mufflers would work too. OR simply finding an aftermarket exhaust with a box type/chambered muffler (what the cars originally had).
Or you could just not make any friends because they sound a little boring.
I find it odd that in modern day society neighbors can play music all night and drink alcohols; rodents can scream at the very top of their lungs for days on end and stab each-other with pointed sticks; Dogs may bark and defecate nearly indefinitely; a renovation can occur next to you with big bearded men using those pneumatic pecky things. But you drive your hot-rod a couple times a week and all hell breaks loose.
Setup..
Make sure you take off the exhaust before you move and rev the heck out of it. Then change it at your new place. 😀 you'll forever be remembered.
I don't know where you live, but if you do those things after hours around here the cops come and issue you a citation. We sleep well in these parts.
Setup..
Stock C5 exhaust with headers? Perish the thought!
Get the Z06 TI exhaust. Much quieter than the B&B's and much better flowing. If you get a used system, make sure it is the 2002-2004 system. The 2001's had an extra set of cats, which will rob you of power.
I tell my neighbors that how's America sounds. actually only one of my neighbors complains and surprisingly the one with the new born baby ask me to rev it. go figure.
I find it odd that in modern day society neighbors can play music all night and drink alcohols; rodents can scream at the very top of their lungs for days on end and stab each-other with pointed sticks; Dogs may bark and defecate nearly indefinitely; a renovation can occur next to you with big bearded men using those pneumatic pecky things. But you drive your hot-rod a couple times a week and all hell breaks loose.[/QUOTE]
Are these actions acceptable behavior in your hood? What ghetto do you live in?!?!I would own an Abrahams tank in that hood, nothing that resembles a Corvette forsure.
I had corsa extremes, they were great until I went to 383, cam, headers, with cats, it was way too loud and I have no neighbors to worry about, went with stock Ti and it is a huge difference. There are guys pushing out over 800hp through them!
i am running LG superpro headers 1 7/8'' along with there x pipe into a corsa indy system and with a ECS superchargers and to be honest in low rpm the car is louder then stock but not enough to annoy the neighbors until i romp on it...corsa's are the way to go
Setup..
Darn would have traded with you but I have since did a bypass mod on my stock and now it is loud
The Bullets are loud even without the headers. Yes, replacing them with something like a set of Tis or even a less aggressive aftermarket catback would help.
The earliest I drive home from work is at 10:30 PM and that's the reason I went from a bullet muffler to the LG big 3. It's not stock-like quiet, but it's not brash like the bullets.
The rest of my setup is 1 7/8" Kooks with the high-flow cats 3" all the way back.
There's no way tiny mufflers that are just this side of straight pipes can be quiet. You need a real muffler unless you want your neighbors to call the cops on you for a noise violation every day.
