Digital Torque Wrench
Old Nov 14, 2015 | 08:55 AM
blmw's Avatar
0blmw
Former Vendor
St. Jude Donor '12
Default Digital Torque Wrench
Need a Holiday Gift?
Here you go: our Digital Torque Wrench w/ Blow Molded Case for $90 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: vette
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid through December 2015, and only for the lower 48 states.
Old Nov 14, 2015 | 09:39 AM
huesmann's Avatar
huesmann
Do you have a 3/8" version?
Old Nov 14, 2015 | 07:54 PM
rodsvet's Avatar
rodsvet
They do not. I asked this question last year. If they would produce a 5-75 lb. for similar money, I would be all over it!! The size of the wrench in the video is too large for what I need. But at $90 it still is a Hell of a buy. Rod
Old Nov 19, 2015 | 10:14 PM
blmw's Avatar
0blmw
Former Vendor
St. Jude Donor '12
Thanks. That is totally correct!
BLMW
Old Dec 1, 2015 | 08:52 PM
blmw's Avatar
0blmw
Former Vendor
St. Jude Donor '12
Get someone you like a great Holiday gift.
Old Dec 2, 2015 | 07:44 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I have one of these and it's a good wrench. My only con would be the fact it eats batteries like crazy and the auto off function is very quick. Which means you have to power it back on and reset the desired torque setting a lot. Pulling the batteries after each use is a good idea for sure!
To Digital Torque Wrench
