No start
Old Nov 15, 2015 | 07:10 AM
Srkegler's Avatar
Srkegler
Default No start
Just got my 04 out of the shop Friday after they replaced the torque tube. Drove it home (10 miles). Went to the store Saturday (2 miles). Car started, put it in reverse to back out and it died.
It's currently at the dealership but I'm curious if there is something they could have left unplugged or damaged to cause a no start condition. Engine cranks but acts like it isn't getting fuel. Sorry, didn't get to pull any codes.
Old Nov 15, 2015 | 07:33 AM
El original's Avatar
El original
I think you will be telling us what happened before we suggest a solution, lol. Keep us posted.
Old Nov 15, 2015 | 01:38 PM
Srkegler's Avatar
Srkegler
Yeah, not much to go on. What I'm hoping is they may have forgot to plug in some wiring on the saddle tanks. I "think" the engine feeds from one tank and the pump transfers fuel between the tanks. Since I have less than 1/2 tank, one side may be empty. Not really sure how many parts he had to remove to get the torque tube out but it looks like the saddle tanks might have been in the way.
Old Nov 15, 2015 | 01:51 PM
209TIME!!!'s Avatar
209TIME!!!
wow I hope they do not rob you on the repairs
Old Nov 15, 2015 | 02:56 PM
corveball's Avatar
corveball
7th Gear
is there any gas in it?
Old Nov 15, 2015 | 04:46 PM
Srkegler's Avatar
Srkegler
yes, haven't had any problems with the gauge, has slightly under 1/2 tank. Was just curious is that gas could be in a tank that isn't feeding to the engine. Guess I'll find out Monday when the mechanic has a chance to look at it. Thank god for extended warranty. Cost them close to $3600 for the torque tube and labor.
Old Nov 15, 2015 | 06:47 PM
cor28vettes's Avatar
cor28vettes
Could be something simple as this (#21, not 12)
http://forums.corvetteforum.com/show....php?t=3670906
Old Nov 17, 2015 | 07:17 AM
Srkegler's Avatar
Srkegler
Well, got raped. They found "intermittent ground circuit in connection". Of course no fault of the stealership that this connection failed just after they worked on the car.
$85 labor, $77 tow bill, $5.95 shop supplies. Luckily there are several other dealers in the area.
Old Nov 17, 2015 | 08:09 AM
bikeriderga's Avatar
bikeriderga
Any grounding connection issues before you took her in? Any codes being thrown?
Old Nov 17, 2015 | 06:05 PM
Srkegler's Avatar
Srkegler
Nope, no codes. Car just died. Had to be something in the fuel system, probably the fuel pump that transfers gas to the other tank.. Pretty sure he had to unplug the harness that runs alongside the tunnel to get the torque tube out. Either didn't plug something back in or screwed up the connector. Don;t think it makes good business sense to lose a customer over something so trivial. No parts needed, looks like about 1 hr of labor.
Old Nov 17, 2015 | 10:40 PM
cor28vettes
For chassis ground issues check your chassis ground connectors
http://forums.corvetteforum.com/showthread.php?t=896875
Old Nov 18, 2015 | 10:18 AM
73Corvette's Avatar
73Corvette
Originally Posted by 8VETTE7
Just as an FYI there is only one electrically powered fuel pump on the C5 (also the C6) and that is the one in the drivers side tank. It feeds fuel to the motor and also delivers a small stream of gas to a jet siphon pump located in the passenger tank. The siphon action causes fuel in the passenger tank to be "siphoned" into the drivers side tank in larger volume than the stream the fuel pump feeds to the passenger tank. So if the problem was fuel pump related it had to be the connector to the pump located in the drivers side tank or the ground for the fuel pump..
Dealer was very foolish NOT to take responsibility for the problem since they worked in that area. If it were me I would be having a LONG talk with the service manager and if I didn't get satisfaction I would be talking to the general manager. But that is just me when someone I pay for service screws up.
To No start
