Smelling Coolant
Old Nov 20, 2015 | 01:51 PM
Borderdawg's Avatar
Borderdawg
Default Smelling Coolant
I have a 2004, ZO6 with under 22K miles. After driving it and parking it in the garage, I can smell coolant, mainly from the passenger side area. There’s no leakage coming from any of the hoses that I can see. I was wondering if I have a small leak at the water pump gasket. I’m thinking the leak is so small that when it leaks it evaporates from the engine heat. I talked to a few mechanics and was told “not worry about it and to let the leak show itself.” I was thinking of doing an overnight pressure test to pinpoint where it’s coming from. Any thoughts???
Old Nov 20, 2015 | 02:57 PM
stu12dozen's Avatar
stu12dozen
Originally Posted by 8VETTE7
Pressure tester should help locate it.
Pressure test is the only way to know for sure.
Old Nov 20, 2015 | 03:01 PM
Borderdawg's Avatar
Borderdawg
Pressure test it is!!! Thanks.
Old Nov 20, 2015 | 08:27 PM
El original's Avatar
El original
Hopefully its not the heater core...if the windows fog up on heat/defrost setting its your culprit. Keeping my fingers crossed for you. Rob
Old Nov 20, 2015 | 11:12 PM
striper's Avatar
striper
I hope this will help you. Awhile back I had a similar problem. I didn't smell it until I shut the car off. I had no visible leaks anywhere. I don't remember who suggested this to me, but I replaced the cap on the coolant tank and it fixed the problem. Got it on Amazon for slightly more than $10.
Old Nov 21, 2015 | 07:22 AM
ricoZg's Avatar
ricoZg
I had a similar issue. Found out I had a small crack at the radiator outlet tank just above the lower radiator hose.
Old Nov 21, 2015 | 12:19 PM
huesmann's Avatar
huesmann
Fortunately, you can get a Dorman overflow tank for under 50 bones. Unless the Dorman part has a bad rep on Vettes (I've used them to good effect on other cars)?
Old Nov 22, 2015 | 09:50 AM
huesmann's Avatar
huesmann
http://www.dormanproducts.com/p-75722-603-140.aspx
Old Nov 23, 2015 | 09:19 AM
huesmann's Avatar
huesmann
I originally found it at RockAuto, but checked Dorman's site to be sure.
Old Mar 15, 2016 | 02:22 PM
Borderdawg's Avatar
Borderdawg
Finally got around to performing the pressure test...leak is coming from right under the water pump pully and leaking on to the harmonic balancer. Is my water pump bad or is it the upper water pump seal?
Old Mar 15, 2016 | 02:46 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Time for a new water pump. Haven't changed mine yet and I have the same issue. Not to hard to do from what others have said.
To Smelling Coolant
