Gas Mileage
Old Nov 22, 2015 | 07:20 PM
Bux's Avatar
Bux
5th Gear
Default Gas Mileage
I have a 99 Vette which according to the on board computer module calculates MPG at 17, however in reality it is about 10-12, which I calculated by dividing the mileage traveled by the amount of gas needed to fill the tank.
Any suggestions as to why the difference?I asked my mechanic if gas could be leaking while driving and was told no. What else could cause this difference?
Old Nov 22, 2015 | 07:48 PM
idahoskiguy's Avatar
idahoskiguy
Reset the reading and try it again. Betting it will be closer on your next full up.
Old Nov 22, 2015 | 07:56 PM
v98roadie's Avatar
v98roadie
Trucker
I dunno but my MPG dropped significantly when I added headers, a vararam and 3.73 gears to my A4. The tires don't last near as long either. I can't figure it out but I can't wipe the grin off my face!
Old Nov 22, 2015 | 08:04 PM
Getting an MPG by using a manual calculation method will almost always vary somewhat from the car's computer simply because it is very difficult to ensure you put exactly the same amount of fuel back in the tank that your car burned out. But is should not vary that much.
Many say that the on board computer calculates high, but IMO it is really pretty accurate, at least mine calculates out pretty close to what I can determine using a manual method.
How is your car running - any performance issues? Have you been stuck in traffic a lot where the MPG could decrease significantly? Have you been driving differently than you normally do - i.e., more spirited driving?
Old Nov 22, 2015 | 08:26 PM
sirdano's Avatar
sirdano
Weird I get 19 city driving and last trip from Dallas got 27 on the highway.
Only mods are a modified air housing and bypass mufflers which should do nothing to MPG.
Old Nov 22, 2015 | 08:27 PM
grantv's Avatar
grantv
Although I've never manually calculated my mileage in the Z, I have in our van a couple times for reasons that don't matter. I fill it completely (completely!) before and after, tracking the distance. I'd say there is very little room for the error doing it this way.
P.S. computer tells me 15.7 city driving.
Old Nov 22, 2015 | 09:32 PM
Arodman's Avatar
Arodman
Default mileage
My readings are pretty accurate, as mentioned its hard to calculate the exact fuel consumed manually. Mine, I have a Stock A4 I get 19 in the city and up to 28MPG on the highway on Cruise Control
Old Nov 23, 2015 | 12:00 AM
stu12dozen's Avatar
stu12dozen
Do you reset the computer each time you fill up? If not, then your 17mpg reading is a culmination of your ongoing fuel economy since the last time it was reset.
Or........ is it possible you made a mistake in the math?
I have an on board computer in three of my cars and although not always perfect, they do seem to be quite accurate.
Old Nov 23, 2015 | 08:34 AM
Mickeyrx70's Avatar
Mickeyrx70
I've manually calculated my mileage only 3 or 4 times & it's always been very close to the car's computer calculation. I haven't reset the fuel mileage for at least a couple years now, and it's at 25.5 mpg average for what's pretty close to 50/50 city/highway driving.
Old Nov 23, 2015 | 09:40 AM
Bux's Avatar
Bux
5th Gear
Thanks for the responses. I have set the trip counter 4 times after filling up and it continues to calculate at about 10-12 MPG. As of now I have driven about 110 miles and the fuel gauge is about half, which would get me about 225-250 on a tank of gas. Performance seems OK. Don't know what else to do.
Old Nov 23, 2015 | 12:39 PM
garline14's Avatar
garline14
Press the fuel button on the dash and bring up the average mpg on the dic. Hit reset and your average mpg should go back to zero. Resetting the trip only will not reset your average mpg. Your 12 mpg average that it is showing right now is probably just the ongoing average since the last reset.
Old Nov 23, 2015 | 02:17 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Your mileage may vary...
In my wife's '14 ATS, every single time I have manually checked the mpg vs what the DIC says, it is SPOT ON, within .1 - .2 mpg.
In my '12 Malibu, it is a lottery - sometimes close, sometimes +/- as much as 2 - 3 full mpg.
I reset both every fill-up.
I've never checked my Vette manually...the DIC typically reads high 20's on a tank. It will knock down low 30s on the hwy. I think this is telling me I don't use WOT enough...
To Gas Mileage
