Question about a part.
Old Nov 24, 2015 | 10:20 AM
spawncba's Avatar
spawncba
Default Question about a part.
I assume this is the fuel filter, but just want to double check. It is right on top of the exhaust where the axle connection to mufflers is, above transmission. It is leaking fuel on the side facing the engine bay.
Just want to make sure it is the fuel filter.
Old Nov 24, 2015 | 10:22 AM
Yes, that is a fuel filter.
Old Nov 24, 2015 | 10:34 AM
spawncba's Avatar
spawncba
Thank you for the quick response sir.
Is there a special tool required to remove it?
Old Nov 24, 2015 | 11:21 AM
dadaroo's Avatar
dadaroo
Yes, but they can be found at any auto store. Not expensive. I can post the info on removal when I get home.
Mr. Sam
Old Nov 24, 2015 | 12:19 PM
zachaeous's Avatar
zachaeous
Already answered
Old Nov 24, 2015 | 12:25 PM
spawncba's Avatar
spawncba
Thank you dadaroo, I would appreciate that sir.
Old Nov 25, 2015 | 06:01 AM
dadaroo's Avatar
dadaroo
Here are links to the types of fuel line fittings and methods for disconnecting.
Plastic
https://www.dropbox.com/s/3q1s6m7t26...nects.pdf?dl=0
Metal
https://www.dropbox.com/s/1pyf2v3q1l...nects.pdf?dl=0
To Question about a part.
