Which Fluids to Change??
Old Nov 30, 2015 | 02:05 PM
tmirisola's Avatar
tmirisola
Default Which Fluids to Change??
So far the GM dealer has been very good to me with questions and requests for the 1999 C5 I am buying. I told the dealer I wanted the fluids changed and they said OK.
Which fluids/filters should I tell them I want changed??
Old Nov 30, 2015 | 02:11 PM
3sACROWD's Avatar
3sACROWD
If they cannot prove recent changes and are agreeing to changing fluids, then I'd want the following changed:
Brake
Clutch (if a manual transmission)
Transmission
Power steering
Rear Differential
Coolant
Oil
Old Nov 30, 2015 | 02:26 PM
CQRT's Avatar
CQRT
Brake
Transmission
Power steering
Rear Differential
Coolant
Oil
This . . . .
Old Nov 30, 2015 | 02:29 PM
Christian327's Avatar
Christian327
Brake
Transmission
Power steering
Rear Differential
Coolant
Oil
x2
And make sure they are the correct fluids too. The 97-00 requires a specific type of transmission fluid.
Old Nov 30, 2015 | 08:07 PM
tmirisola's Avatar
tmirisola
Thanks for the tip :-)
This forum is awesome
Old Nov 30, 2015 | 08:43 PM
Brake
Transmission
Power steering
Rear Differential
Coolant
Oil
That pretty much covers it - have them change all the fluids. That way you know at least the fluids are OK.
Old Nov 30, 2015 | 09:51 PM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
If you have to prioritize, the tougher ones to change are
coolant
PS fluid
clutch
The others are very easy to do yourself
Old Dec 1, 2015 | 07:36 PM
Clancy209's Avatar
Clancy209
u should change oil/fuel filters while u r at it.
Old Dec 2, 2015 | 05:54 AM
Sids04's Avatar
Sids04
Pre 2001 M6 use non synthetic trans fluid, or the amsoil stuff. There is like 11ty billion threads on this subject.. Google search will net great results.. Lots of times the dealership goobers are clueless..
To Which Fluids to Change??
