Hi,
Does know what connector the c5 uses on for the fuel door actuator ? I want to fabricate a locking fuel door for my Monte Carlo using an actuator from a c5 but i'm not sure what connector type it uses. If anyone could help me I'd greatly appreciate it.
Thanks Mr Sam, you've been very helpful.
I'll try to find a source for the connector, lock and terminals. I did find a seller on ebay that would include the connector with the actuator, so I may just go that route.
I have a few more questions.
On the c5 corvette, is the actuator located in the trunk area or in the fender above the splash guard ? I saw that on the c6 it's in the trunk area, but the cable looks longer than that of the c5.
What type of switch does the corvette use for the actuator, a rocker similar to that of a door actuator?
I'm just trying to get my ducks in a row. When I get the actuator installed and working I'll definitely follow up.
In the fender but access requires going into the fender and access via the truck to remove.
You must use a MONENTARY switch like a push button one so it does not stay energized.
Let me know if you need anything else.
Mr. Sam
Webster's revised Corvette Edition defines a "MONENTARY switch" as; A push button switch that energizes a circuit only when pressed and can be purchased with ordinary money. (usually a lot of ordinary money)
