Cam/Heads cost
Old Dec 4, 2015 | 05:48 PM
Mark0632's Avatar
Mark0632
Default Cam/Heads cost
I'm in the market for my first c5. If I get a stock one I'd like to do heads/cam. What is the cost parts/labor to do a proper Camswap with aftermarket/ported heads with tune. A guy quoted me close to 5k, seems a bit ridiculous to me. What do you guys think?
Also he said porting the LS1 heads is a waste of time an to just buy/port LS6 heads. He also said you need a lift to do the job(because I mentioned I might do it myself). Any truth to the above?
Any feedback is appreciated.
Ben
Old Dec 4, 2015 | 06:32 PM
Qkslvrc5z's Avatar
Qkslvrc5z
To do an optimized heads cam swap, parts and all, your looking at an easy 2-2.5k in heads, $400 on a cam, headers $800 or more, head bolts, timing chain, gaskets, depending on heads you use 3-500 in rockers. These are just the main parts you'll need, not including an intake, catback exhaust, underdrive pulley, and pushrods, so even if you manage to get all that for $3500 that's still $1500 in labor, and that's fair on labor.
So in all honesty, 5k is very reasonable.
Old Dec 4, 2015 | 06:38 PM
Crussader's Avatar
Crussader
Since you are in the market, the absolute cheapest way is to buy a car that already has the heads/cam done.
Old Dec 4, 2015 | 07:09 PM
Qkslvrc5z's Avatar
Qkslvrc5z
^^ what he said haha
Old Dec 4, 2015 | 07:34 PM
grantv's Avatar
grantv
Do you have a HP target? Regardless, the most cost effective course has been mentioned.
Old Dec 4, 2015 | 07:42 PM
Mark0632's Avatar
Mark0632
400 RWHP is roughly the target, I've seen ones with headers for 10k and cammed/heads/headers ones for 13k(both high mileage obviously) I just wasn't sure if maybe it was cheaper to buy the 10kk and do the heads/cam myself
Old Dec 4, 2015 | 08:47 PM
I'd say $5K would be a minimum to get a heads/cam job done. England Green, a respected vendor here, offers to do a cam swap and with labor it runs right at $3500. Add in the cost of the heads and associated parts needed for them, and you'll be over $5K for sure.
Old Dec 4, 2015 | 09:56 PM
tbrowne's Avatar
tbrowne
$5K is about right if you want a quality job with quality parts.
Old Dec 4, 2015 | 10:04 PM
firemailwv's Avatar
firemailwv
As others have said, 5k is reasonable. I was over that with heads, cam, fast intake, ls2 throttle body and Ls7 clutch. Put down 441hp to the wheels.
Old Dec 4, 2015 | 10:36 PM
dbgoodwin's Avatar
dbgoodwin
$3500 for just a cam swap!? There is absolutely no reason it should be over $2500 max, and that is on the high side still. A shop in Charlotte quoted me $1750 for everything including tuning, with all drivetrain upgrades.
Old Dec 5, 2015 | 02:00 AM
grantv's Avatar
grantv
Get a Z06, drop in some headers, CAI and a tune and you're just about there. No engine mods. Also has deeper 1st gears, wider tires, less weight...
Old Dec 5, 2015 | 02:09 AM
Qkslvrc5z's Avatar
Qkslvrc5z
If your just wanting around 400whp, do a mild cam from eps, tick or BTR, headers, CAI, a clutch (stall if auto) with a good tune you can easily break that mark, could even get a set of 243s for roughly $500 and make a little more power. Car will drive virtually stock and make good power throughout the power curve. No need for heads and cam if your not looking for a max effort set up. Could do all that for roughly $2500 in parts.
Old Dec 5, 2015 | 04:45 AM
scott5's Avatar
scott5
Which shop?
Old Dec 5, 2015 | 05:55 AM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
I added a set of 243 (Patriot) heads and a cam to mine a few years after I bought it. A friend helped install the items for a few hundred and the retune was on $50 as the tuner had already tuned the car previously. The cost of the heads & cam was roughly 2k
Old Dec 5, 2015 | 07:42 AM
Rob Petyo's Avatar
Rob Petyo
A set of TrickFlow 215's will run $2,500.00 alone if you're going to do a heads/cam build, then at least use the correct heads
Old Dec 6, 2015 | 08:59 AM
CactusCat's Avatar
CactusCat
Yeah, if that's the only thing you're doing, that's about right. But the OP asked for Heads and Cam. And you won't get the bang for the $$ if you don't at least add headers.
Old Dec 6, 2015 | 11:03 AM
dbgoodwin's Avatar
dbgoodwin
Originally Posted by scott5
Which shop?
Called aquadale speed shop. He actually saw me on this forum and sent me a message, which turned into some emails and then into a quote. Really cool guys, been following them on facebook and seeing some of the stuff they put out.
$3500 for headers and cam is reasonable, but just for a cam swap it's nuts.
To Cam/Heads cost
Old Dec 6, 2015 | 11:15 AM
Not4spd's Avatar
Not4spd
For that cost I'd just buy a used supercharger kit and install it myself and be over the 400whp mark.
Old Dec 6, 2015 | 12:31 PM
Black 02's Avatar
Black 02
Don't forget to do new lifters and lifter trays while in there on a higher mileage car.
Old Dec 6, 2015 | 12:59 PM
Navybluevette's Avatar
Navybluevette
St. Jude Donor '12-'13-'14-'15-'16-'17
I would be very careful doing this, I have heard many bad stories of guys doing this. Might end up end up with some else mistakes and end up costing you more in the long run. I would say 5K is on the low end by the time you add parts, labor and tune.
