headlight question '01
Old Dec 5, 2015 | 02:34 PM
Brack c's Avatar
Brack c
Default headlight question '01
Working on my newly acquired 01 , i noticed one of the headlight lenses is cracked and the other is slightly hazy. ...
My question is this , i see clips holding them knto the buckets ...can they ve replaced or do you have to replace the entire assembly??
Old Dec 5, 2015 | 10:31 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
They can't be separated as far as I know
Old Dec 5, 2015 | 11:54 PM
I've not seen anyone post that the lenses can be separated - I think you have to replace the light assembly as a unit.
Old Dec 6, 2015 | 12:51 AM
CactusCat's Avatar
CactusCat
Sorry for you problems. Did some searching and Vetteman appears to be correct. Have to buy the whole thing At least we don't have near the problems with headlights that the C6 guys have. Those exposed headlights are always getting cracked.
Old Dec 6, 2015 | 01:38 AM
Brack c's Avatar
Brack c
Thanks for yalls input
Old Dec 6, 2015 | 09:20 AM
huesmann's Avatar
huesmann
Lenses can be separated (heat in oven, pry apart), but nobody makes replacements. You'll need to replace the entire housing.
Old Dec 6, 2015 | 12:15 PM
momo20's Avatar
momo20
yes any modern headlight that is plastic in the sense of the word can be taken apart, after all they go together, so with that said as far as i know they do not make replacement lens for the out side of the vette light the only one i have ever see is for the c6 vettes, here is where they aftermarket comes in from various different sites you can buy aftermarket complete replacement headlight housing that will replace your stock dull OEM housings
Old Dec 6, 2015 | 01:33 PM
JR-01's Avatar
JR-01
https://www.partswebsite.com/hendric...i=2&type=parts
Old Dec 6, 2015 | 03:18 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
if you're going to replace the housing anyway, have a look at our Bi-xenon ACA kit:
http://shop.radioflyerinnovations.co...lights-015.htm
Old Dec 6, 2015 | 07:41 PM
Sam Handwich's Avatar
Sam Handwich
Some of the best money I ever spent on a vehicle upgrade. You will be shocked by the improvement.
To headlight question '01
