Going to store car "Need Advice"
Old Dec 9, 2015 | 08:21 AM
tmirisola's Avatar
tmirisola
Default Going to store car "Need Advice"
I am transitioning moving to FL full time. My 1999 Corvette will be sitting in the garage in FL for months at a time. What should I do before I store the car for a few months at a time?? Disconnect Battery???
Also, what to do before starting after months in garage.
Old Dec 9, 2015 | 08:26 AM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
I use a trickle charger on mine when stored. Just check everything over real good before you start it up. Done deal
Old Dec 9, 2015 | 09:49 AM
Here's what I do:
  • Put Sta-Bil in gas tank and fill tank with gas. Best to do this when tank is about 1/4 full so Sta-Bil is mixed in both tanks.
  • Change oil and filter.
  • Detail car - interior/exterior/engine bay - wax if desired.
  • Put a few extra PSI in tires and I place an old piece of carpet under each tire to keep them off the comcrete floor.
  • Place Bounce dryer sheets in interior and engine bay to discourage any critters from taking up residence. Moth ***** work well also. Some put moisture absorbing packets in the interior too.
  • Hook up battery tender if electricity is available. If electricity is not available, remove battery and store in safe place.
  • Place car cover over car to keep dust off painted surface.
  • I do not start the car unless I plan to drive it for a reasonable distance.
Old Dec 9, 2015 | 10:50 AM
JR-01's Avatar
JR-01
With the humidity down there you may want to put a de-humidifer in the garage or at least have a small fan circulating the air.
I remove my battery for storage, but some use battery tender in the car. Your choice. If you don't the battery will be dead when you go to start it.
Old Dec 9, 2015 | 11:32 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I wouldn't leave a battery tender on the car for "months at a time" if the storage space was completely unattended....
Old Dec 9, 2015 | 11:34 AM
JR-01's Avatar
JR-01
Me neither. A home down the street burned down. The cause was determined to be trickle charger on a stored car in the garage.
Old Dec 9, 2015 | 02:04 PM
bajapointe's Avatar
bajapointe
Simply leave a set of keys with me and I'll take it around the block for ya once and a while to keep everything in working order.
Old Dec 9, 2015 | 02:32 PM
3sACROWD's Avatar
3sACROWD
Humidity will definitely be a concern. Tubs of Damp Rid or some other dehumidification would be a good idea.
Putting the car away clean is good for the car and you will have a car ready for your return.
Old Dec 9, 2015 | 06:54 PM
Mike98SilVert's Avatar
Mike98SilVert
Originally Posted by JR-01
With the humidity down there you may want to put a de-humidifier in the garage or at least have a small fan circulating the air.
It gets pretty hot and humid in the summer. Maybe ventilate the garage by installing vent grating in the ceiling access panel into the attic above. The heat down here will drain the battery faster than the cold up north. Dryer sheets are a good idea.
SW Florida is the lightening capital of the world. I would not suggest leaving a battery on a tender unless you have Surge Shield installed by FP&L to protect from lightening strikes. With an estimated 1.5 million lightning strikes in Florida each year you could experience a power surge and damage the charger or the cars electrical system or maybe even cause a fire. I had FP&L install it in my home and I still would not feel comfortable leaving a battery on a tender for extended periods while i was away. I would remove the battery and keep it inside where it's cooler. Before we moved here permanently we would leave the A/C on 78 degrees and have a neighbor periodically check the house.
Old Dec 9, 2015 | 10:08 PM
Amazing1's Avatar
Amazing1
Here's what I do:
Thanks so much for the great advice Vetteman Jack. Just curious, what does placing each of the slightly over inflated tires on a piece of carpet do, as opposed to just sitting on the cement garage floor?
To Going to store car "Need Advice"
