[Z06] Trouble?
Old Aug 28, 2002 | 08:49 PM
edv2122's Avatar
edv2122
Default Trouble?
Maft set at +15 base - 6 WOT. Anyone see a problem with these settings for long term motor durablitiy? Engine mods listed below. :cheers:
Old Aug 28, 2002 | 08:55 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Default Re: Trouble? (edv2122)
Did you scan this car to determine these settings? Did you put the car on the dyno with a wideband to determine the WOT settings?
If you didn't scan & wideband the car then you are shooting in the dark.
+15 base is getting high. You may start to lose some timing. You should scan the car to see what is going on.
