[Z06] Battery Disconnect
Old Dec 21, 2015 | 12:07 PM
TomcatMike's Avatar
TomcatMike
Default Battery Disconnect
I have a 2002 Z06. Gonna replace the valve springs this week. This will entail disconnecting the battery for the work.
I read through the Owner's Manual about reconnecting the battery. The only thing of honorable mention is the anti-theft code for the radio. I no longer have the stock radio. I have a nice Kenwood unit with XM Satellite tuner and Bluetooth.
Other than the radio issue, it appears that the reconnection of the battery prior to start should be a normal, unremarkable event.
Are there any additional things to consider?
Thanks,
Mike
Old Dec 22, 2015 | 12:16 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Nope.
Old Dec 26, 2015 | 08:36 AM
Black 03 Z06's Avatar
Black 03 Z06
Had my battery disconnected many times and never had an issue with anything on the car.
Make sure to take off your watch/rings before work working on the battery. You do not want to short yourself out.
Old Jan 1, 2016 | 09:59 PM
striper's Avatar
striper
I have disconnected my battery since my Kenwood installation and upon reconnecting I haven't lost any radio settings, so you should have no problems at all.
Old Jan 10, 2016 | 12:37 AM
LT1driver's Avatar
LT1driver
ditto everything said above.
Old Jan 10, 2016 | 02:58 AM
Trash's Avatar
Trash
An 8mm internal ratcheting box end wrench will make life much easier when disconnecting the battery.
Old Jan 10, 2016 | 08:25 AM
TomcatMike's Avatar
TomcatMike
Default Summary
Roger all the previous responses. My work is now done and the valve springs have been replaced and the car is back in "battery," so to speak.
As for my radio, the Bluetooth recognition of my phone was still good, but all my pre-set channels for regular FM radio and XM radio had gone away, had to set those back up. Also, the clock had reset to 00:00, and all the speaker and stero-sound settings had reset back to default.
But back in bidness now.
Cheers and Happy New Year to all.
Mike
To Battery Disconnect
