[Z06] paint help
Old Dec 27, 2015 | 09:53 AM
03 Z-oh-6's Avatar
03 Z-oh-6
Originally Posted by jonnyc
if you get the buffer i listed above you won't have any problem with the 6" kit.you would have to lay on it pretty hard to stop the pad from spinning.
like stated above,the important things with this kit it priming the pad fully,not using too much product on the pad,and i blow the pad clean with an air compressor after each panel.
Blow the pad clean after each section. You cannot do a hood without blowing out the pad. Some panels are smaller than others, but still, blow out after each section. When using MF pads, spent paint and polish accumulate very quickly, which results with less cut and more marring(haze) if not blown out frequently. As far as the 6.5" pads, sure, you can use them, but they won't be nearly as effective as 5.5" pads on an 8mm random orbital(HF).
Old Dec 27, 2015 | 08:04 PM
jonnyc's Avatar
jonnyc
i totally agree the smaller pad is more effective.but the hf buffer is pretty powerful and i think the bigger pad is more safe for someone that doesn't have a lot of experience with a buffer.with the 5" it almost becomes a rotary buffer where the 6" will stop if they apply to much pressure.you can still get the swirls out with the larger pad but some areas may take extra applications to fully remove.i just hate to see someone burn their paint getting to aggressive and i don't think you can with the 6" pad.
that's why i don't ever recommend a rotary to someone that doesn't have much experience.and this is the best system for a dual action buffer that i have seen.
yes the hood is large and you need to blow out the pad atleast once .the door you can almost do if you're not using a lot of product but it's still a good idea to blow out the pad half way through the door.i usually blow it out every other time i apply product.the pad works best when it's clean
Old Dec 28, 2015 | 07:20 AM
appliance guy's Avatar
appliance guy
I appreciate all the input. The 5" kit is on the way. Trust me, I'll take it easy.. I don't want to damage the paint either !
Old Dec 28, 2015 | 07:36 AM
03 Z-oh-6's Avatar
03 Z-oh-6
You will NOT do damage to the paint with an 8mm Harbor Freight DA. To compare it to a rotary(even with 5" pads) is not even close. TRUST ME. I'm glad you went with the 5" kit. You did get a 5" backing plate too, correct? The HF comes with a 6".
Old Dec 28, 2015 | 07:58 AM
appliance guy
Yes, the kit comes with a backing plate.
Old Dec 28, 2015 | 08:01 AM
03 Z-oh-6's Avatar
03 Z-oh-6
Old Dec 28, 2015 | 08:40 AM
turboexec's Avatar
turboexec
I look forward to see how your car turns out. I've got the same issue with my '01 Blk z06.
Old Jan 24, 2016 | 10:24 PM
appliance guy
Finally got around to doing my hood today with the previous recommended products. Very easy to do and great results ! Not perfect, but 10x better ! All swirl marks and water spots gone ! Touched up chips with Dr. Color chip, finished with Miami shine wax. There are a few scatches I couldn't get out, think I need a more agressive pad for those. Vast improvement though, will do the rest of the car this week. Thanks again for all the advice !
Old Jan 25, 2016 | 11:38 AM
03 Z-oh-6's Avatar
03 Z-oh-6
Awesome!
