Knowledge base is greater here than a truck forums! The question is about my 1997 GMC truck 5.7 460L) I replaced both front 02 sensors after getting a code. I'm wondering if I should also replace the downstream sensors, or is it a waste of money. It seems to run just fine now!
Thanks a bunch!
Thanks! I thought maybe replacing all 4 at the same time might improve mileage a bit (for about $60 bucks). The original code was just for the r/h upstream which took care of the problem.
