I'm interested in getting a specialty tool called an "oil filter cutter". These things open the end of an oil filter to allow inspection of the filter. What do you use? I've seen a few on the internet and they seem a bit expensive. Thoughts? Thanks!
I picked one up on the net for $40.00 with shipping, it seems pretty well made. Out of respect for the forum vendors, I will not mention the name of the place it got it from, but k
eep looking they are not that expensive.
If I wanted to do that, I would just use a Dremel and a cutting disc . Cost? Zero.
I confess however that I never check on any of that stuff - no filter inspections or oil analysis. I have just changed the oil and filter regularly, and 18 years later, I am still using zero oil between changes. And this car is not babied in any way, shape, or form.
That would add metal particles into the filter, kind of ruining the whole idea of cutting it open.
Been several different routes trying to get by cheap.. Just pay the money and get a good one.
Personally, I do not know why you would ever want to cut one open. I spent many years as both pit crew and engineer for various formula cars in Europe - I do not recall anyone ever cutting open an oil filter. We just ran new oil and a new filter for every race.
It was usually done after a new motor was broken in or a major malfunction to determine if there was internal damage..
Typically performed during an oil change or anytime engine condition or performance is in question, oil filter inspection is a great troubleshooting tool as well. Oil filter inspection begins by simply removing the filter from the engine, placing it in a pan and letting it drain for 10-15 minutes prior to being cut. An Oil Filter Inspection Tool (KRC1201R), offered by KRC Racing, is recommended when performing this task. While it may be tempting to grab a hacksaw, it's best to use a specialized tool since it cuts clean, similar to a can opener, without creating metal debris that may be confused with engine wear. Follow by clamping the tool in a vise and placing the filter so that the outer housing may be cut as the thumb screw is tightened. Slowly rotate the filter by hand while tightening the thumbscrew until the filter has been cut all the way through.
Once the housing has been cut completely open, remove the filter element. Continue by using a utility knife to carefully cut the end caps off of the element so that the "pressure side" of each pleat may be examined for debris. Keep in mind that all things mechanical wear and there will always be a few tiny pieces of bearing material, silicone sealer, etc. lodged in the element. Most engine wear found is typically no bigger than a pencil head. If the engine has just been rebuilt, expect to find a generous amount of assembly lubricant in the filter as well. Again, no cause for concern. On the other hand, if the pleats contain a generous amount of what appears to be bearing material or other metal fragments, further investigation may be in order. Removing the oil pan and inspecting the bearings then becomes the next step.
I would wager that top F1 teams have cut open a filter or two.
With all the racing I have done in the past, having a street rod for many years and having over 143,000 miles on my Z06, I have never had an issue where I thought it might be necessary to cut open an oil filter. I always change my oil a little earlier than recommended and use top quality oil and the best filter you can buy. Never had any engine issues. Guess I've been lucky.
I have this one and cut my filter open on our drag car every 30 passes (that is when I change oil) tells you real quick what/if something is starting to come apart. Having that for a 9.0 second motor to me is a necessity, street cars not so much, but I do cut them open for fun from time to time.
