c5 convertible top adjustment
Old Dec 31, 2015 | 09:53 PM
conestoga's Avatar
conestoga
8th Gear
Default c5 convertible top adjustment
I just bought a beautiful c5 Commemorative Edition convertible with 23K miles and I would like to know if anyone knows how to adjust the top or where I can get information on how to do it
Happy New Year
Conestoga
Old Dec 31, 2015 | 10:12 PM
docmiller7's Avatar
docmiller7
What type of adjustment are you needing? I have 02 vert.
Old Dec 31, 2015 | 10:31 PM
conestoga's Avatar
conestoga
8th Gear
When the top is up, it doesn't look even across the bottom where it sits on the car, and the windows don't seal correctly. I can hear air leaking thru when driving.
Old Jan 1, 2016 | 07:19 AM
dadaroo's Avatar
dadaroo
Here is how to adjust the top. If the window does not seal afterwards it is either the weather striping or the window adjustment. I can provide info on that also if you need it.
https://www.dropbox.com/s/wcjhnxfzsl...tment.pdf?dl=0
Mr. Sam
Old Jan 1, 2016 | 02:15 PM
conestoga's Avatar
conestoga
8th Gear
Mr. Sam
Mr. Sam,
Thanks for the info.
The driver's side window has inboard/outboard play while the passengers side does not. If I could get the info on the window adjustment, I would appreciate it.
Old Jan 1, 2016 | 04:36 PM
Sam Handwich's Avatar
Sam Handwich
Originally Posted by conestoga
Mr. Sam,
Subscribed
Old Jan 2, 2016 | 05:50 AM
dadaroo's Avatar
dadaroo
Here is the window adjustment. It could be the regulator so if you need more info on that I have it.
https://www.dropbox.com/s/z3r5hjn8oy...edure.pdf?dl=0
Here is how to remove the door panel. This first one has some regulator info also.
http://www.vetteessentials.com/instr...or_handle.html
Mr. Sam
To c5 convertible top adjustment
