C5 buzzing coming from behind gauge cluster
Old Jan 2, 2016 | 02:02 PM
rome-1's Avatar
rome-1
7th Gear
Default C5 buzzing coming from behind gauge cluster
I have a loud buzzing noise coming directly behind my gauge cluster. I have I have the console out and the gAuge cluster partially out . I seem to be stuck on how to get it completely out . Help (:
Old Jan 2, 2016 | 02:25 PM
Use the instructions from this link to get the cluster out.
http://www.vetteessentials.com/instr...zel_howto.html
Old Jan 2, 2016 | 02:27 PM
rome-1's Avatar
rome-1
7th Gear
Thanks 👍👍👍
Old Jan 2, 2016 | 06:39 PM
rws.1's Avatar
rws.1
might just be a weak battery.....
Old Jan 2, 2016 | 09:34 PM
95wht6spd's Avatar
95wht6spd
Or hornets!
Old Jan 3, 2016 | 02:16 AM
Ceedub53's Avatar
Ceedub53
Have you pulled your codes? Could be a drivers side HVAC air actuator.
Old Jan 3, 2016 | 06:54 AM
dadaroo's Avatar
dadaroo
Most likely the Chime speaker. If the IPC fails this can happen. Most people just remove a wire to it. Other option is another IPC. Just know the mileage is stored in the IPC.
Mr. Sam
To C5 buzzing coming from behind gauge cluster
