Picture below. Its a torn hose behind #7 cylinder coil. Not throwing a code for it and it's been torn for a while from the look of it.
Also pulled my tranny pan and found these bolts. They do not look like the correct bolts. Please advise. If they arent Where's the best place to find these bolts locally.
Thanks any advice on the hose size or part # or exact part name?
Sorry I know the bolt is right I guess the whole "conical" washer does look as conical as I was expecting. I can maybe see a tad bit of dish to them. There was alot of leaking on the trans gasket as whoever did it previously didn't even hand tighten the bolts. Didn't have to use a rachet to take them off
Ya I understand it needs to be torqued, my question was how conical looking should the washers be. I wanting to know if the washers need replacing or not as they look flat to me but the service manual shows they should have a decent amount of bend to them.
that I cannot answer, don't know if it was mine I would use them !!!
