Warning - Wells Programmable TPMS sensors
Old Jan 8, 2016 | 07:25 PM
marc a's Avatar
marc a
Default Warning - Wells Programmable TPMS sensors
I'm not the brightest bulb in the box so maybe I am the only one that was educated the hard way.
Autozone sells the Wells Programmable TPMS sensor. The type that we use are fairly new. Wells is owned by NGK Spark Plug.
Autozone did not tell me that "programmable" means programmed by a Wells Programmer which is proprietary AND that the sensors had to be programmed BEFORE they were installed.
The programming tool costs over 400 and because the product is new, there are very few programmers out there.
It would have been too easy for Autozone to have a programmer at each store, or at least make one available locally, AND tell you that the sensors have to be programmed.
Hopefully this post will save some one from making the same mistake that I did.
Old Jan 8, 2016 | 07:58 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I hate it when that happens !!!
Old Jan 8, 2016 | 08:00 PM
Pappy11's Avatar
Pappy11
Thanks for The Info...........
Old Jan 8, 2016 | 08:19 PM
Thanks for the warning. Were they that much cheaper than say OEM sensors? Sometimes to save a few bucks it costs you a lot in frustration.
Old Jan 8, 2016 | 09:38 PM
C5RClone's Avatar
C5RClone
Thx.
Old Jan 9, 2016 | 12:18 AM
marc a's Avatar
marc a
45 each. You are absolutely right; however, it just never occurred to me that Autozone would be selling a product earmarked for my specific car that could not be used generically.
I spoke to a Wells tech and he is trying to help me out. I'm sure that Wells will want to make sure that Autozone and the other vendors make it clear to the general public that programming is required.
If NGK really wants to make a dent in the sensor market they should have provided programmers to their vendors. My 2 cents.
Old Jan 9, 2016 | 12:38 AM
marc a's Avatar
marc a
Originally Posted by thisMSGgood4me
If the sensors haven't been installed yet, you should have no trouble returning them. If they have been installed, I hope either Autozone or Wells can help you out with the programming. Good luck whichever way it goes.
Thanks, they were just installed with new tires so either way they will have to be removed and programmed or removed and replaced.
Old Jan 9, 2016 | 11:25 AM
yaknow's Avatar
yaknow
that is just plane stupid
Old Jan 10, 2016 | 01:46 PM
jackthelad's Avatar
jackthelad
Just put OEM sensors in - all you need to "program" them is a couple $ magnet. And the price seems similar - check Tirerack, they sell them.
Old Jan 12, 2016 | 11:27 PM
marc a's Avatar
marc a
Ok so Wells has called me twice and was very accommodating and apologetic. They are sending me 4 new sensors pre-programmed for my car. I will then remove the ones I have and return them to Autozone for a full refund.
Needless to say I will be testing the sensors before they are installed.
Old Jan 13, 2016 | 05:50 AM
cvm's Avatar
cvm
There are numerous aftermarket tire sensor programmers. Seek out a good tire store, Find a "tech" (haha) with a BRAIN who knows how to use said programmers. Many stores have more than 1 type. They cant have a block on / in to the hz from the sensor cuz diff systems want to read diff hz. I could be so wrong, but I know a guy who I bet could get them to talk. Good Luck
Old Jan 13, 2016 | 01:51 PM
marc a's Avatar
marc a
Wells has already admitted that the sensors can not be programmed with any other programmer. Whether that will be tolerated by the market or governing authorities is a question for another day.
To Warning - Wells Programmable TPMS sensors
