C5 HUD problems
Old Jan 10, 2016 | 12:17 PM
Ronnie Bishop's Avatar
Ronnie Bishop
1st Gear
Default C5 HUD problems
I bought my 03 C5 used, and the HUD worked fine for a while but then I noticed that the brightness had a mind of its own. Then partial information was displayed, then the buttons on the switch had no effect on the HUD, except the height adjustment, which works fine. Occasionally every light in the HUD lights up momentarily at startup, sometimes they all stay on bright for days then magically go dark. The switch has no effect on page or brightness. I have all the components out of the car in order to upgrade dash lights to LED and would like to fix the HUD while it is accessible. I figure it has to be the switch, the instrument cluster or a harness since the projector obviously has power. Any experience with this HUD problem? Thanks. Ronnie
Old Jan 10, 2016 | 12:21 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
good place to start !!!
https://www.corvetteforum.com/forums...d-display.html
Old Jan 10, 2016 | 02:45 PM
Hard to say exactly where the problem is, but if you need to replace multiple components, I think Cultrag Performance sells all the pieces in a package at a reasonable price.
Old Jan 13, 2016 | 09:18 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you for the referral. Unfortunately a few months ago GM discontinued the C5 HUD. We got all of the new HUD's in the country we could and we are all out.
Old Jan 13, 2016 | 11:32 PM
00PewterVert's Avatar
00PewterVert
Cruising
I would check and clean all the connections from the hud/switch to be sure there isn't a dirty or loose one. You never know it could be as simple as that.
To C5 HUD problems
