drivers door problems
Old Jan 14, 2016 | 01:27 AM
davek515's Avatar
davek515
Cruising
Default drivers door problems
As title states the driver door work sometimes and also takes time off. Sometimes the key is needed to enter car, and I must flip lock at times to get out. Wondering if it could be door module and if so does anyone rebuild them. Thanks mine is a '99 frc
Old Jan 14, 2016 | 04:24 AM
dogwoodvette's Avatar
dogwoodvette
Default Door issues
Go to the Tech Section and check out one of the stickys on electrical. Could be the module but could be the wire harness where door mounts to the A pillar/frame. Would think the exterior handle is a mechanical connection and not electrical.
Old Jan 14, 2016 | 05:56 AM
dadaroo's Avatar
dadaroo
Exactly what is not working???????????????????
Mr. Sam
Old Jan 14, 2016 | 08:01 AM
davek515's Avatar
davek515
Cruising
Mr. Sam
The lock on the door.
Old Jan 14, 2016 | 02:15 PM
dadaroo's Avatar
dadaroo
So the Unlock works but the Lock function does not?
Mr. Sam
Old Jan 14, 2016 | 09:25 PM
davek515's Avatar
davek515
Cruising
Mr. Sam
Both sometimes don't work.
Old Jan 16, 2016 | 06:24 AM
dadaroo's Avatar
dadaroo
I think it is your LDCM.
Here is how to access it:
http://www.vetteessentials.com/instr...or_handle.html
If you want DIY info to do the fix let me know, otherwise:
http://www.autoclockrepair.com/c5_corvette_electronics
Mr. Sam
To drivers door problems
