engine prep and security
Old Jan 20, 2016 | 01:27 AM
cherokee433FL's Avatar
cherokee433FL
Default engine prep and security
i have some work to do on my C5 coming up....a serpentine belt and a plug change and i have gone through some thought on how to render the engine lifeless since i want to increase as much as possible a safety factor in order to save what fingers i have. i have thought the best way is to remove the negative lead from the battery. any thought out there on the usual and most effective method? i used to work on all my cars years ago, and never gave it a thought.
Old Jan 20, 2016 | 01:43 AM
Ferg03 Z06's Avatar
Ferg03 Z06
That is a simple task to do and should not cause any busted knuckles. For changing the plugs and wires just use a few different extensions and even a flex extension. If you are replacing the wires then it shouldn't really matter if you damage the other ones taking them off, so a pair of pliers will be useful.
When you replace the plugs be sure to add some anti-seize to the threads and lithium grease to the end where the boot connects. This will make it MUCH easier to remove them/check them if you need to in the future.
The serpentine is extremely easy and will literally take 5 minutes, just use a buddy to hold the 15mm socket(if I remember correctly) used to move the tensioner pulley toward the engine to release the tension on the belt.
Old Jan 20, 2016 | 08:00 AM
Yes you can remove the negative battery cable, but I haven't heard of any unexpected engine starts by simply doing a belt and plug swap. Most factory service manuals do state to disconnect the battery so it won't hurt to do so. If you have the theft lock set on the radio, be sure you have the code so you can reset it if needed. Be sure to do the plug swap while the engine is cold and the advice above about tools to use is very good. The only difficult plug to get out is the #7 one so take your time and use a flex extension.
Old Jan 20, 2016 | 09:00 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
FWIW, and not to be sarcastic, in the 45 years I've been "wrenching" on cars, I've NEVER disconnected the battery, to do a spark plug change or belt change. IMHO, in today's cars, with all of their electronic crap, you might inadvertently wind up doing more harm than good.
Old Jan 20, 2016 | 09:52 AM
JR-01's Avatar
JR-01
Keep the key out of the ignition and the kids out of the car and you should have no mishaps while changing the belts and plugs.
Old Jan 20, 2016 | 01:10 PM
cherokee433FL
Default thanks
thanks to all of you for your insights you have offered.
ken
Old Jan 20, 2016 | 11:11 PM
Choreo's Avatar
Choreo
Ditto.
I use a belt tensioner tool to unload the tensioner, but a ratchet and socket will do the same thing. I always work from the Driver's side and remove/install the belt from the alternator first and last - I have found that is the easiest way for me working alone.
Old Jan 21, 2016 | 01:09 AM
cherokee433FL
Default thanks a lot
Originally Posted by Choreo
Ditto.
i appreciate your help. i remember early days working on cars...a 69 ford pickup. everything is very different these days, especially these corvettes. i will have to go buy a belt tensioner tool.
To engine prep and security
