Help asap ( reduce engine power )
Old Jan 23, 2016 | 07:22 PM
Gangsta_Vette's Avatar
Gangsta_Vette
Default Help asap ( reduce engine power )
How's it going guys I have a 2001 c5 corvette 5.7 M6 bolt ons an cam (ms4) running 36#injectors so my question is why does my car go into reduce engine power in cold starts I checked my dtc an got p0106c an p1514hc an there's more codes but this were the only codes coming out when car was getting tune other codes were HC if I keep the RPMs up in cold star at idle it will not go into reduce engine power ....... So there's something going on wit the MAF or tps. But I dnt kno were to start I got a volt meter an had key on engine off an cheked the tps so ik is a 2 sensor in 1 so I cheked the 2 middle wires been the voltage reference an I was getting .3 on both wires don't I need to atleast get .5 .6volts idk if I'm doing it right can someone let me kno if I'm doing something wrong or have had this problem after tune thanks....
Old Jan 24, 2016 | 02:37 AM
bikeriderga's Avatar
bikeriderga
Go here to lookup codes
http://computer-logic.co/Obd2Lookup
This is my site and it is free.
Here is the info I got by running these codes
PID Description Category Sub Category
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem Powertrain Main
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem Powertrain Fuel and Air
P1514 High Load Neutral/Drive Fault Powertrain Transmission
Old Jan 24, 2016 | 02:43 AM
TXghost's Avatar
TXghost
If you are running an air filter with oil (like K&N), try switching to a non oiled filter and clean the MAF.
Old Jan 24, 2016 | 07:11 PM
Gangsta_Vette
Yes I'm running a filter that has oil but honestly is been a while since I cleaned I really dnt use my car but I removed the filter an turn car on an it still goes to reduce power . I cheked my map sensor an I had a line not connected just the hose dat goes to booster . This are the codes I pulled out of dic
P1637 HC
P0103 HC
P1571 HC
P0106 c
P1514 HC
P1638 HC
Old Jan 24, 2016 | 07:59 PM
bikeriderga
P1637 HC
P0103 HC
P1571 HC
P0106 c
P1514 HC
P1638 HC
Go to my site, sign up, and do a search for the codes.
There is a bonus coming for those who sign up in the next few months. Promise you will love the bonus.
Old Jan 24, 2016 | 10:42 PM
Gangsta_Vette
Ok I'll check it out bro ... An another thing I checked my MAP sensor an I kno is hold on by a clip an some type of orange rubber oring but I noticed it moves side to side but is kinda normal but wat threw me off is that u can wobble it up an down pretty bad like bad so I'm thinking that's y is throwing me that code so Ima take out the intake an see wats going on .
To Help asap ( reduce engine power )
