Stupid question.
Old Feb 2, 2016 | 07:24 PM
TXghost's Avatar
TXghost
Default Stupid question.
Still very new to the C5. I tried "search" and 15 minutes later, still no answer so...
What is "Twilight Mode"?
I was flipping through the options and it is off.
Old Feb 2, 2016 | 07:30 PM
dbgoodwin's Avatar
dbgoodwin
Pretty sure it senses when it starts to get dark outside and turns on the lights.
Old Feb 2, 2016 | 07:34 PM
LoneStarFRC's Avatar
LoneStarFRC
Did you try Twilight Sentinel?
Old Feb 2, 2016 | 07:52 PM
TXghost's Avatar
TXghost
I have no idea what twilight sentinel is.
I leave for work at 0400 hours. When I arrive I switch off the headlights and then turn on the parking lights, until someone arrives to open the office. I was wondering what it did, but did not want to be stuck with the headlights on when I get to work.
Old Feb 2, 2016 | 07:58 PM
69monzacpe's Avatar
69monzacpe
From the owners manual:
Twilight Sentinel® (Optional in
United States, Standard in Canada)
Twilight Sentinel® can turn your lamps on and off for you.
A light sensor on top of the instrument panel makes the
Twilight Sentinel® work, so be sure it is not covered.
You can customize your vehicle to turn Twilight
Sentinel® on or off, except for vehicles first sold in
Canada. See Driver Information Center (DIC) on
page 3-48 to turn this feature on or off.
When Twilight Sentinel® is turned on, you will see the
following happen:
• When it is dark enough outside, the front turn signal
lamps (DRL) will go off, and the headlamps and
parking lamps will come on. The other lamps
that come on with headlamps will also come on.
• When it is bright enough outside, the headlamps
will go off, and the front turn signal lamps (DRL)
will come on, as long as the exterior lamp switch is
in the OFF position.
If you start your vehicle in a dark garage, the automatic
headlamp system will come on immediately. Once you
leave the garage, it will take about one minute for
the automatic headlamp system to change to DRL if
it is light outside. During that delay, your instrument
panel cluster may not be as bright as usual.
Make sure your instrument panel brightness control is in
full bright position. See “Instrument Panel Brightness
Control” under Interior Lamps on page 3-17.
With Twilight Sentinel® turned on, you can idle the
vehicle with the lamps off, even when it is dark outside.
First set the parking brake while the ignition is in OFF.
Then start the vehicle. The lamps will stay off until
you release the parking brake.
Twilight Sentinel® also provides exterior illumination as
you leave the vehicle. If Twilight Sentinel® has turned
on the lamps when you turn off the ignition, your lamps
will remain on until:
• The exterior lamp switch is moved from OFF to the
parking lamp position, or
• a delay time that you select has elapsed.
See Driver Information Center (DIC) on page 3-48 to
select the delay time that you want. You can also select
no delay time.
If you turn off the ignition with the exterior lamp switch
in the parking lamp or headlamp position, the Twilight
Sentinel® delay will not occur. The lamps will turn off as
soon as the switch is turned off.
As with any vehicle, you should turn on the regular
headlamp system when you need it.
There's an old acronym I use -"RTFM"...JK
Old Feb 2, 2016 | 08:03 PM
TXghost's Avatar
TXghost
Thank you so much!
I have no FM to read...
Old Feb 2, 2016 | 08:07 PM
It automatically turns on your headlights when the light sensor says it is dark enough to do so. Then when you shut off the car, it automatically turns the lights off. It does not turn on just your parking lights - it raises the headlights.
A number of people, including myself, have chosen to keep the twilight sentinel off since there are many times, like backing out of a garage, where you do not need the lights to pop up. This avoids undue wear and tear on the light motors.
Old Feb 2, 2016 | 08:09 PM
vettpapaw's Avatar
vettpapaw
OM is on line also.
69monzacpe's Avatar
69monzacpe
Originally Posted by TXghost
Thank you so much!
http://justgivemethedamnmanual.com/c...owners-manuals
Old Feb 2, 2016 | 08:13 PM
91stroker's Avatar
91stroker
Its a love story between a wolf and a vampire, or something like that.
Old Feb 2, 2016 | 08:44 PM
Nyt_Muves's Avatar
Nyt_Muves
I think one of them sparkles or something
Old Feb 2, 2016 | 09:00 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Old Feb 2, 2016 | 09:04 PM
91stroker's Avatar
91stroker
hahah, oh yeah cant forget the sparkles.
Old Feb 2, 2016 | 09:22 PM
TXghost's Avatar
TXghost
Mine will stay off.
Thanks for the link to the FM.
Thanks for the help and prompt answers.
Thanks also for the sparkly vampire help. I don't know how I could ever be expected to negotiate sparkly vampires without the help of members here and a link to a Corvette owners manual. Well, that and a stake...
JR-01's Avatar
JR-01
The Twilight Sentinal is a feature that automatically wears out the gears in the pop up headlight mechanism. Best left off.
Old Feb 2, 2016 | 09:27 PM
73Corvette's Avatar
73Corvette
To Stupid question.
By Michael S. Palmer | 2026-06-03 09:39:05
