[Z06] Recommendations for Alignment?
Thanks guys
EDIT -http://www.pfadtracing.com/blog/wp-content/uploads/2010/01/corvette-alignment.pdf
If you're willing to give up some tire life, then you can put in some more negative camber and enjoy the car more. If you are doing some autocross then go all the way to about -2 degrees in the front and about -1.3 in the back and enjoy the car.
If you want to maximize tire life then back off some.
The reality is that if you only use your car 3,000 or 4000 miles per year, the tires are going to get hard and performance will fall off in a few years anyway. So you can put in small amounts of negative camber, the tires will last longer, but they will get hard and won't have stick worth a darn anyway. If you put in more negative camber the tires will be bald in three or four years on the inside edges, but that's about the time you should really be trashing them anyway...
So like -2.0 front and -1.4 to -1 rear. Issue is what you can get is dependant on ride height. SO just max the front then set the rear to something more, or less negative. i think my car is at -1.8 front and -1 rear.
Caster is uneven left to right and maxed, but my alignment guy said he doesn't like not maxing it on the stock bolts as he believes its more likely to change if the bolt isn't maxed. He sets up most of the cars for miles around, he is about 40 minutes from me, but the only show in town. So I suspect he has real life experience to back this up.
I run 3/16" total rear toe in, to help with braking specifically into 5 at RA, it does keep the rearend in line noticably over just running 0 rear toe. 0 toe in front to keep the tires happy.
Here is from the GM service manual. I went with the "service preferred" settings with me in the car and 2/3 tank of gas. Made the alignment guy nail those settings.
Very happy with those settings
