Pre purchase advice wanted. 1999
Old Feb 13, 2016 | 01:27 PM
Ducati Guy's Avatar
Ducati Guy
Default Pre purchase advice wanted. 1999
Just looked at my first ever C5 at a dealer. A 1999 coupe. 80K. Made a deal contingent on further inspection. I think it is a good price. Needs tires and rear rotors. As of now that is all i can see. $13k is the price. Down from asking of $14800.
Here are a few questions. On the drivers side in the engine bay there is what looks like a sealant in a few spots on the frame rail Just under the large tank. I think the tank is the washer fluid tank. It is seen from above not underneath. It is shiny and hard and not on the other side. No idea if this is normal or indicates a repair. Frame rail looks intact with no signs of being bent or straightened. Auto Check report shows no accidents.
The removable roof panel is the glass type. It creaks a good amount over bumps. quiet on smooth roads. Dealer says this is normal, they all do it. Do they?
Having never driven a C5 i do not know how much of the exhaust is normal to hear. Hard to describe but I hear quite a bit under acceleration. Guessing this is normal. After all it is a sports car. Also get some burbling when letting off the gas. Normal?
Ok.......that's all for now. Hoping some of you experienced folk can lend a hand.
Graham
Old Feb 13, 2016 | 01:39 PM
The glass top should not creak when going over bumps - mine doesn't. There are adjustments that can be made to tighten it down and help eliminate the creaks and rattles. I have some files on the adjustment procedure and if you'd like a copy, just PM me your e-mail address.
A stock exhaust should not burble when you let off the gas and is actually pretty quiet. Pics of what you have on the car now would help in identifying if it is a stock system or aftermarket.
Pics of the sealant would help too.
Old Feb 13, 2016 | 01:48 PM
tmirisola's Avatar
tmirisola
I have a 99 C5 with both tops and neither creak. Is the top aftermarket or original GM? I also have a factory exhaust and it cannot be heard inside during acceleration or back off. I would assume it's an aftermarket exhaust if you can hear it. I just looked at my engine bay around the windshield washer tank and do not see any sealant of any type.
Have the dealer check for you if the recalls for the steering wheel & seat belts were done back in 2001. If not, the steering wheel lock could be a problem down the road.
Pictures are worth 1,000 words
Old Feb 13, 2016 | 02:20 PM
Ducati Guy's Avatar
Ducati Guy
Good info. I did not get to snap any photos of the sealant. Will ask the salesman to send me a few. Will also try to find out of exhaust is stock.
If you could send along the tightening info that would be helpful. 3wolves@optonline.net
Old Feb 13, 2016 | 02:21 PM
Robert Perkins's Avatar
Robert Perkins
Go to the top of the general section and read the two stickies on buying a C5
Old Feb 13, 2016 | 02:22 PM
Ducati Guy's Avatar
Ducati Guy
Good advice on the recalls. will check. Will also inquire if exhaust is aftermarket. Cause you certainly do hear it as i described. Even though it is a sports car i did not think it should be that noticeable.
Will ask the dealer to get me some photos of the sealant.
Thanks. Big help.
Old Feb 13, 2016 | 02:24 PM
Ducati Guy's Avatar
Ducati Guy
cannot find the stickies. help?
Old Feb 13, 2016 | 02:39 PM
Robert Perkins
Go to C5 general see top pf section second group down heading sticky
Old Feb 13, 2016 | 11:07 PM
Nyt_Muves's Avatar
Nyt_Muves
Both my tops have no squeaks or rattles. My exhaust has a good amount of back snap when deceleration but I have borla exhaust. The stock exhaust sounded like a family sedan. Not aggressive at all. Get a pic of the exhaust.
Old Feb 14, 2016 | 12:06 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I have a '99 with both tops and neither squeek at all. My exhaust burbles on decel but I don't have stock exhaust.
Old Feb 14, 2016 | 10:40 AM
Velocity_Vette's Avatar
Velocity_Vette
I feel it's good you got the price down where you got it. $14,800 for what you have specified the car initially needs is a bit high and what you have worked it down to is reasonable with that mileage and initial needs.
In addition to the top latch adjustment procedure I would also check if the car needs new window seals. You will want to price these now if it does need them. Replacing the entire set of seals on a C5 is by no means cheap and cars can experience issues with weather stripping within relatively low mileage, especially if the top is frequently removed.
I still have stock exhaust on my car. It does produce a relatively louder sound than initially expected from this sort of car. Keep in mind that there is virtually no sound deadening in the rear; you have a large piece of glass and below that is a tub structure hovering directly above the transaxle and the exhaust routing. You should be able to hear some of the back pressure and gurgle to a small degree under deceleration but it should not be excessive.
Old Feb 14, 2016 | 10:49 AM
raff's Avatar
raff
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22
Here:
https://www.corvetteforum.com/forums...ion-files.html
https://www.corvetteforum.com/forums...must-read.html
Old Feb 14, 2016 | 11:58 AM
Fcar 98's Avatar
Fcar 98
One thing you can check for on the creaking top. With the top removed, there are little rollers that are in the latch holder on top of the windshield, They should roll freely, I had that problem. Do not over tighten those latches, Especially the lexan top, may over stress it.
Old Feb 14, 2016 | 01:41 PM
jrprich's Avatar
jrprich
I would pull the codes from the DIC. But the dealer may have cleared them all before putting it up for sale. 97-00 can have ABS module issues.
Old Feb 14, 2016 | 01:55 PM
jackthelad's Avatar
jackthelad
And make sure the computer update for the gas gauge problem has been done.
Mind you, even as an owner of a '98, personally if buying now, I would not buy an early car - too many non available spares like the EBCM (anti-lock module) and the steering wheel position sensor for starters.
Old Feb 14, 2016 | 03:47 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Don't bother with the GM recall fix for the column lock they had four and did not fix the issue instead see if one of these is installed, THIS IS THE ONLY FIX !!!!!! http://www.complianceparts.com/lmc5whoneeds1.html
BTW I love my 99 Coupe !!!!!!!
Old Feb 23, 2016 | 01:29 AM
Ducati Guy's Avatar
Ducati Guy
an update on newly obtained info about my potential purchase.
the 'sealant' appears to be I believe this is the product....http://www.eastwood.com/rust-encapsulator-27490.html . It stops the rust dead in it's tracks and prevent it for continuing. Have been told it is used a lot by people restoring old cars to stop rust on floor boards and other areas.
Th exhaust is after market ....http://shop.bbexhaust.com/C5-Bullet-...-FCOR-0100.htm
Any and all comments on either or both of these would be appreciated.
To Pre purchase advice wanted. 1999
