2004 Corvette Questions
Old Feb 15, 2016 | 07:59 AM
steig's Avatar
steig
Default 2004 Corvette Questions
I am looking at a 2004 Corvette with 19,000 miles on it. I am in the process of making a deal. The question I have is the 2004 Corvette gas tank problems that can cost over 2K to repair. Anyone have any info on this, the serial numbers of the car are in the range of the gas tank issue.
Is this something that WILL happen or MIGHT happen ? I have researched this topic and read different opinions.
I know GM extended the warranty, but only for 10 yrs.
Old Feb 15, 2016 | 08:04 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Didn't even know about this problem and I've had my 04 for about 8 years without issue. *knock on wood*. Was there a recall?
Old Feb 15, 2016 | 08:19 AM
dadaroo's Avatar
dadaroo
Read Post 2 here.
https://www.corvetteforum.com/forums...el-system.html
There are plenty of C6s that can provide a good tank if you need it.
Mr. Sam
Old Feb 15, 2016 | 08:28 AM
Here's some info that might help answer your questions.
Old Feb 15, 2016 | 08:41 AM
steig's Avatar
steig
Appears that it could be a problem for some Corvettes.
Old Feb 15, 2016 | 08:58 AM
69monzacpe's Avatar
69monzacpe
It could be a problem, the risk increases with age. I avoided the VIN range when searching and purchasing mine. I figured why pay for a problem then worry about whether it will jump up and bite you?
Old Feb 15, 2016 | 09:22 AM
DetroitPlac's Avatar
DetroitPlac
So, are those outside of the VIN range "safe"? Or at least less prone to failure? Mine is a 2003, but it has the new fuel system.
Old Feb 15, 2016 | 11:53 AM
DetroitPlac
Originally Posted by thisMSGgood4me
The problem was prone to occur on Vettes within a certain VIN range within the 2004 model year, so your 2003 is as safe as it can be. Doesn't mean it could never happen, but it's not prone to.
Makes sense. I guess I can sleep a bit better.
Old Feb 15, 2016 | 12:47 PM
steig's Avatar
steig
C5 with a build date approx. October 22, 2003 through March 19, 2004
Old Feb 15, 2016 | 10:18 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
OP, If you want to test the car, simply fill it up, but don't top off the tank. When the pump clicks off, take the nozzle out. When you start it up, if there is a very strong smell of gasoline that doesn't dissipate after 5 or 10 miles, it may have the problem. The best way to tell is, after filling it up, put it up on a lift, you'll see the wetness near the gas tank(s).
BTW, this problem can occur with any C5 or C6 (not sure about the C7). A while back I did some research on this gas tank issue and found several instances where C6s had the problem. The group of 04 C5s referenced are more prone to having the problem.
Old Feb 16, 2016 | 04:27 AM
SG Lou's Avatar
SG Lou
Or VIN range 45110258 through 45125500
I got lucky, my 04 was built after.
Old Feb 16, 2016 | 07:16 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I also got lucky my Vin was later
Old Feb 16, 2016 | 09:52 AM
captaineddie's Avatar
captaineddie
I'm not so lucky either. My last five are 25337. :-(
Old Feb 16, 2016 | 10:50 AM
Sox-Fan's Avatar
Sox-Fan
I'm in there. 58k miles. race it every other weekend. no issues, no concern that there will be an issue. I've got larger things in life to stress out over than the possibility that something old might act old.
This is nothing. It's an automobile that is over 10 years old. Age happens. Things wear out. We fix them and move on. This is no different.
Old Feb 16, 2016 | 12:35 PM
BobbyC5's Avatar
BobbyC5
I'm in there too. 21187. We've had a trouble free six years together so far.
To 2004 Corvette Questions
