oil pressure question
Old Feb 18, 2016 | 12:08 PM
Wolfie's Avatar
Wolfie
Default oil pressure question
I just sold my 02 C5 and the buyer called with a question. The dash oil gauge shows 80psi (which I believe is the maximum for the gauge) and the digital reading on the dic is 131psi. Is this normal? Thanks!
Old Feb 18, 2016 | 12:20 PM
Kmcoldcars's Avatar
Kmcoldcars
It is not normal. The oil pressure sending unit has died and needs to be replaced. This is a somewhat common failure.
Old Feb 18, 2016 | 12:24 PM
Wolfie's Avatar
Wolfie
Thanks for your input. Is the sending unit expensive and/or difficult to change?
Old Feb 18, 2016 | 12:26 PM
jjaaam's Avatar
jjaaam
The unit itself isn't that expensive, but you will get different opinions as to how hard it is to change. Many say you have to remove the intake manifold to get decent access to it. Some have claimed to be able to get it out without doing so, and others have taken to cutting a hole in the plastic dash cover to gain access.
Do a search on it and you'll come up with a lot of information...personally I do not have first-hand experience with this as mine hasn't gone bad.
Old Feb 18, 2016 | 12:35 PM
Christian327's Avatar
Christian327
Sending unit is like around 40 bucks...it is a time-consuming task as far as I've read. My sending unit is faulty as well and need to switch mine out.
Old Feb 18, 2016 | 01:38 PM
ehillard0's Avatar
ehillard0
My gauge had similar readings until I replaced the oil sending unit. I replaced the sending unit without cutting a hole or removing the intake manifold, but it was a major PITA and there was quite a lot of swearing involved. If I had to do it over, I would remove the intake manifold.
One tool that helped me was a pair of Crescent Double-X Long Nose Pliers.
Old Feb 18, 2016 | 01:54 PM
runner140*'s Avatar
runner140*
Purchased two pair at Harbor Freight for $15.00 Sure makes many jobs a lot more easy.
Old Feb 18, 2016 | 02:46 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Replaced mine as well. There is a great article on here somewhere that lists the parts needed to install the sensor on a remote mount. Since I have a FAST intake, this is the best option since clearances are tighter. So it is now on a 10" braided line and resides under the driver fuel rail cover. If ever it dies again? 3 minute swap.
Old Feb 18, 2016 | 03:00 PM
Nyt_Muves's Avatar
Nyt_Muves
Removing the manifold isn't that big a deal. Hardest part for me was making sure the little vacuum line on the back of the manifold was plugged back in when reinstalling. There isn't much slack. Do yourself a favor, go to NAPA and pay $10 more and get the brass body sensor.
Old Feb 18, 2016 | 03:42 PM
SilverC54me's Avatar
SilverC54me
Just did one of these last night. I do recommend to replace the intake manifold gaskets also if you go the remove intake route. As the youngest C5 is at least 11 years old they could use replacement.
Also if removing the intake, clean all debris from it before dissasembly. After the intake is out clean the valley area also. A lot of crud gets in these areas.
Gary
Old Feb 18, 2016 | 03:46 PM
jd911's Avatar
jd911
It cost me $340 to have my oil pressure sending unit replaced, at a small town GM dealer, after I missed the 80 psi of oil pressure with the engine not running, when I bought the car. The oil pressure gauge was pinned at 80 all the time.
Jim
Old Feb 18, 2016 | 03:48 PM
Smoken1's Avatar
Smoken1
I found all the info in this thread....
https://www.corvetteforum.com/forums...-for-50-a.html
Old Feb 18, 2016 | 04:31 PM
1Willy1's Avatar
1Willy1
mines been broke for over a year and ive yet to do anything about it
I bought the sendor , its cheap off rock auto, but ive yet to have it installed
Old Feb 18, 2016 | 06:03 PM
Arodman's Avatar
Arodman
Mine went the first yr I bought mine 98 with 36k mileage while replacing I also put in new plugs and plug wires. Figured get that all done while I was working on it. 2 months Prior to that my thermostat went, replace that and the hoses. Right after I purchased the car I took it to a shop had all the fluids and filters changed including trans and rear, put new brakes and shocks the previous owner bought a new battery for the sale. Now just enjoy it! Beside oil and a set of tires due early next year I should be good for another 50-60000 miles before anything else needs work
Old Feb 18, 2016 | 11:45 PM
reath1's Avatar
reath1
Read the posts, gather part and tools. For a mid level diy'er it's still less than a 2 hour job pulling the intake. Relocate it while you're in there. Posts on everything you need for that also.
To oil pressure question
