Vararam C5 intake
Old Feb 18, 2016 | 04:06 PM
Curt Scheibel's Avatar
Curt Scheibel
Default Vararam C5 intake
Bought this ad I'm having a time trying to figure out why it doesn't fit. I called Vararam and the parts guy said it was something I did then transferred me to Tech and the guy told me I might try another intake hose to see if that works. They're sending me two additional hoses and only charging me for one. Has ANYONE tired installing these. Right now it looks as though the easiest way would be to modify the radiator shroud.. Help VETTE FAMILY !!!!!
Old Feb 18, 2016 | 04:43 PM
Sam Handwich's Avatar
Sam Handwich
Pictures?
Old Feb 18, 2016 | 04:44 PM
sfc rick's Avatar
sfc rick
I remember that day 5 or 6 years ago before I supercharged my C5. However after the aggravation it was well worth it.
Old Feb 18, 2016 | 05:34 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I too had trouble with it lining up to the throttle body and I modified my shroud (it was cracked anyway) I have now bought a new shroud but not have tried to install it yet,also my headers rub the steering shaft and what I found is the hydraulic motor mounts will settle so the engine sits lower.(I am replacing my mounts) Did you screw the bottom ducts to your fog lamp ducts if so that is another problem you don't use screws on that and you let the whole system float !!!! watch this also
Old Feb 18, 2016 | 05:41 PM
RVETTE42's Avatar
RVETTE42
I did not have to modify my shroud. You just need to take your time and study your directions. It's a very very tight fit.
Old Feb 18, 2016 | 05:57 PM
Curt Scheibel
Default Thanks....
I've already gone through this with parts and tech . Tech tells me I need a longer hose which they're sending Friday..
Old Feb 18, 2016 | 06:02 PM
Curt Scheibel
Default sorry ...
Originally Posted by Sam Handwich
Pictures?
. for being so dense...I had planned on pics but I've been working and in between I'm in the Vette so this is the first "MOD" I've done.. More to come and I'll try to get some photos....
Old Feb 18, 2016 | 08:43 PM
o2bnkc's Avatar
o2bnkc
They can be PIA, but in the long run you will love it. This is the only true CAI on the market, and you will notice a difference.
Old Feb 18, 2016 | 09:32 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
To Vararam C5 intake
