Recommended Maintenance
Old Feb 18, 2016 | 05:36 PM
captaineddie's Avatar
captaineddie
Default Recommended Maintenance
My 2004 (with 23K miles) is now 12 years old and I figure it's time for some major maintenance before it's time for a summer road trip. The coolant was changed last year and I put new tires on (just in case there was some invisible dry-rot). I have an appointment to get some things done. Right now, I plan on having the brake fluid changed and a new belt(s). The mechanic didn't recommend new hoses, saying that the hoses on it are better than those you can buy today. Does anyone think there's anything else that should be done? I don't want to miss anything that might be important. Thanks.
Old Feb 18, 2016 | 05:45 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I bought my 02 two years ago. Even though it had very low mileage I felt much better about changing every drop of fluid I could.
Low miles or not 10 years is a long tome for that stuff to sit.
Old Feb 18, 2016 | 05:53 PM
Arodman's Avatar
Arodman
Default Other things to consider
I bought my 98 3 years ago, first thing I had done, brake fluid, coolant, had the hoses checked trans. Fluid and filter change along with oil and rear fluid replaced as well. Mine only had 36k miles but those years do add up. Good luck with your ride
Old Feb 18, 2016 | 06:55 PM
captaineddie
Oil and filter were in my plans (even though I forgot to mention them), but I wasn't sure about the transmission. It makes sense to change out anything that's old. Thanks.
Old Feb 18, 2016 | 08:30 PM
c6miller's Avatar
c6miller
Bought my 2003 three years ago with 24K miles. I changed the brake pads & fluid, coolant, diff fluid(looked bad) transmission fluid, belts, oil & filter and hoses. Piece of mind knowing my Corvette is well maintained.
Old Feb 18, 2016 | 09:07 PM
Clancy209's Avatar
Clancy209
Like everyone else the car is 15 years old, I changed all hoses including heater hoses. Wires are a standard change all rubber it gets old and dry. Fuel filter I didn't see mentioned
Old Feb 18, 2016 | 11:43 PM
Good advice above. All fluids should be changed IMO (with the exception of the coolant which you have already done). Hoses, belts, air filter, fuel filter - make sure those are in top shape.
Old Feb 19, 2016 | 06:24 PM
captaineddie
Yeah, at this point I think I'll do all but the hoses. My mechanic, who knows Corvettes very well, says the hoses on the car are still in great condition.
Old Feb 19, 2016 | 06:44 PM
ehillard0's Avatar
ehillard0
The only other things I could think of were:
clean the MAF sensor, throttle body, and radiator
maybe change spark plugs and wires?
maybe o2 sensors?
Old Feb 19, 2016 | 06:50 PM
Kevinl's Avatar
Kevinl
Hoses deteriorate from the inside, so there's no way anybody could evaluate them. Given the low mileage you should be good for a while but keep an eye on them.
Old Feb 19, 2016 | 07:44 PM
Fcar 98's Avatar
Fcar 98
18 years old, 46000, own every mile. I have done,Coolant every 5 years. Battery every five years. Wires and plugs, hoses, belts. Braided brake lines and fluid. Trans and rear end fluids are next for me to do. And I'm sure there are some I can't remember over the years. To me age is just as bad as miles.
Old Feb 19, 2016 | 08:24 PM
sloopdawg's Avatar
sloopdawg
Just got an 01 with 100k
Everything looks good, runs good, sounds good
Anything I need to look for or do?
Old Feb 19, 2016 | 08:35 PM
3sACROWD's Avatar
3sACROWD
Don't forget the power steering fluid and clutch fluid if a manual tranny
Old Feb 20, 2016 | 09:55 AM
captaineddie
Agreed. Age is just as bad as miles. I'm going to discuss everything with the mechanic on the morning I take the car to him. Thanks to all who have replied.
Old Feb 20, 2016 | 10:00 AM
Jeff T.'s Avatar
Jeff T.
When I bought mine I replaced all the fluids. It' good to have a baseline so you know where the car is at.
Old Feb 20, 2016 | 10:48 PM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
Bought a 97 6 years ago and changed all fluids,plugs and spark plug wires. Did wonders for the car and it is still doing well. Bought a 98 yesterday with 14k on it and will change all fluids. Later this summer I will change the spark wires. I have been told they can break down with time.
Old Feb 21, 2016 | 08:33 AM
Fcar 98's Avatar
Fcar 98
Pull plugs too, left in to long make them harder to remove. My 98 changed them at 38000
Old Feb 23, 2016 | 01:43 PM
captaineddie
Thanks for the suggestion. It makes perfect sense.
To Recommended Maintenance
