Paint detailing tips
Old Feb 28, 2016 | 04:33 PM
  #41
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Originally Posted by akapounder
A drill is way to fast !!!!! This is what you should use !!!!
PORTER-CABLE 7424XP 6-Inch Variable-Speed Polisher - Power Polishing Tools - Amazon.com
I use the porter cable also!!
Old Feb 28, 2016 | 05:29 PM
  #42
Sea Vette's Avatar
Sea Vette
I use the porter cable with these meguiars pads
http://www.autogeek.net/meguiars-6-i...discs-3pk.html
with excellent results. The pad that comes with the Porter Cable DA is too rough for polishing.
Old Feb 29, 2016 | 11:26 AM
  #43
chasboy's Avatar
chasboy
Oldtimer
Is there any color consistency with the pads like compound used to be? Red was coarse, white was finer, etc?
Old Feb 29, 2016 | 12:50 PM
  #44
Harley6's Avatar
Harley6
From: Phoenix (Fall/winter/spring); Seattle (summer)
2015 C5 of the Year Finalist
Same here. Being a newbie myself, I took an ultra cautious approach. After getting my Porter Cable, 105, 205 and pads (from Chemical Guys) I practiced on my 03 GMC SUV that has enough bumps and bruises I wouldn't feel bad if I had a mishap with the buffer.
Even then I started with the least abrasive pad and compound, and then went more aggressive if necessary. And, I worked in small areas very slowly. This isn't a quick process but the results were very good for me.
If you have something to practice on before taking it to the Corvette, you should be fine. If I can do it, anyone can.
Old Feb 29, 2016 | 08:34 PM
  #45
Choreo's Avatar
Choreo
No. Different manufacturers sometimes use different color coding systems. For instance here are 4 systems in order of decreasing aggressiveness (this week):
Standard Lake County:
Orange
Blue
White
Black
Red
Yellow
Lake County Hydro-Tech:
Cyan (Blue)
Tangerine (Orange)
Red
Griots Boss:
White
Orange
Yellow
Black
Griots Standard:
Orange
Black
Red
(Yellow is a "scrubbing pad" - NEVER to be used on paint)
and so on...
