Wide fender help
Old Feb 25, 2016 | 01:05 PM
nzcars33's Avatar
nzcars33
Default Wide fender help
Hello I just purchased a set of CC wide fenders from Jeff and if I remember correctly I had read something about the fenders needing trimmed under the lip to avoid tire rub, can someone with the CC fenders or some information help me out with how much and where to trim, pictures would be nice as well, thank you.
Old Feb 25, 2016 | 02:11 PM
Z06copley's Avatar
Z06copley
I just got some in myself, i haven't mounted them yet but it does look like there's room to trim a good amount off. It almost seems like it is extra material from manufacturing. I plan to trim them to have the same amount of lip as the stockers.
Old Feb 25, 2016 | 02:24 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
I have attached a pic just for reference to where the lip is (the pic was just off the net and not sure whose flared fender it is, but describes the location, the yellow line, as the "arc"). If you look at the inside of the arc you will see a ledge that goes back from the full length of the arc towards the wheel. On mine this ledge was over an inch in width. We trimmed it down to about 1/2 inch.
To Wide fender help
