[Z06] 2016 autocross tires?
Old Feb 29, 2016 | 05:03 PM
Jeremy Shute's Avatar
Jeremy Shute
Cruising
Default 2016 autocross tires?
Just picked a C5Z up. I'm looking to autocross it a bit this year, not that I'll be competitive but I'd like to play by the rules and stay in the Stock class.
The Eagle F1's on it were manufactured in mid-2008. The current contenders for replacement (according to Tire Rack) seem to be:
BFGoodrich g-Force Rival S
Bridgestone Potenza RE-71R
Hankook Ventus R-S3 (Version 2)
Kumho Ecsta V720
http://www.tirerack.com/tires/tests/...y.jsp?ttid=202
Just wanted to share some research I did. W and D columns correspond to section width and overall tire and wheel diameter vs. stock.
On stock rims, this seems to be stuff with a close width and height. Nothing closely fits the rear but the R-S3 (Version 2):
Code:
  bfgoodrich_rival_s  255/40R17 (F) W-3.8% D-1.2%
    kumho_ecsta_v720  255/40R17 (F) W-3.8% D-1.2%
       hankook_rs3v2  255/40R17 (F) W-3.8% D-1.2%
       hankook_rs3v2  285/35R18 (R) W-3.4% D-1.1%
   bridgestone_re71r  255/40R17 (F) W-3.8% D-1.2%
But, if you take advantage of Stock class rules (13.4B) it seems you can go up or down 1" in diameter? This would opens up the RE-71R and the Kumho rears:
Code:
  bfgoodrich_rival_s  275/35R18 (F) W+3.8% D+0.9%
    kumho_ecsta_v720  305/30R19 (R) W+3.4% D+0.3%
       hankook_rs3v2  255/35R18 (F) W-3.8% D-1.3%
       hankook_rs3v2  265/35R18 (F) W+0.0% D-0.2%
       hankook_rs3v2  265/40R18 (F) W+0.0% D+3.9%
       hankook_rs3v2  275/35R18 (F) W+3.8% D+0.9%
       hankook_rs3v2  305/30R19 (R) W+3.4% D+0.3%
   bridgestone_re71r  255/35R18 (F) W-3.8% D-1.3%
   bridgestone_re71r  255/40R18 (F) W-3.8% D+2.7%
   bridgestone_re71r  265/35R18 (F) W+0.0% D-0.2%
   bridgestone_re71r  275/35R18 (F) W+3.8% D+0.9%
   bridgestone_re71r  285/35R19 (R) W-3.4% D+2.8%
I think I'm restricted to the stock rim width. So, does anyone know of light/cheap/matching 18x9.5" 19x10.5" wheels?
Old Feb 29, 2016 | 07:24 PM
Sox-Fan's Avatar
Sox-Fan
re71r 17 inch up front, riva-ls 18 inch in the rear.
Take a look at the guys that are winning AS, that is their setup.
There is an autocross and road racing forum where this has been discussed ad infinitum. You should go do some reading before you do any spending.
Old Mar 1, 2016 | 09:21 AM
Jeremy Shute
Cruising
I completely missed discussion in the "General Corvette Topics," doh, thanks.
To 2016 autocross tires?
