I just got new tires g force sport comp2 and now when I let off the gas the back end gets a little squirrely. It only happens when I let off the gas most noticeable above 40 mph. Could the new tires cause this.
Tires pressure is ok.. I can't figure out how the rear can be squirrely and you are driving in a straight line, with rpm band in forth gear and you are off the power. Maybe your idea of squirrely and mine are different.
Sounds like maybe something in the rear suspension is moving around a bit in the dynamic change from accel. to decel.??????? Worn bushings or something??
New tires, with full tread depth are going to be squirrely. Do some burnouts, and they will be fine. There is a reason that race tires have a minimum of tread, or none.
