Window regulator - "noisy"
-Does not make the same sound putting the window up
-If I put the window up only partially (even it I put it ALMOST all of the way up) it will then go back down with no grinding sound
-If I put the window ALL the way back up then it DOES have the grinding sound when I try to put it back down
Did a forum search and didn't see anything - mostly just threads about regulators quitting all together.
Any ideas?
https://www.corvetteforum.com/forums...oing-down.html
So...never mind.
