Reverse lights led????????????
I have some cree bulbs in, they work when I lock or unlock car... They don't work when car is in reverse??? What the hell is the problem
Received 1,261 Likes
is it a 6spd?... if so look on the passenger side of the transmission and there is a 2 wire sensor, that is your backup light switch... unplug it and jump the 2 pins together on the harness end and turn the key to the on position... if the reverse lights come on then your switch is bad, its about $15-20 for a new one
The following 2 users liked this post by neutron82:
c5BigDreamz (03-12-2016),
doublenut9 (03-13-2016)
its automatic
check fuse #21 (10a) in the passenger footwell fuse box
Supporting Vendor
Received 19,307 Likes
'20-'21-'22-'23-'24
possibly a problem somewhere in the gear selector or the wiring from it to the reverse lights, you might have to get out the wiring diagram and start checking... did they work at one point and just stop all of a sudden?
I know they worked before I put the led bulbs in. now the oem light bulbs wont work in reverse either. checked all my fuses and the wires to the backup bulbs look great...
