Battery
Old Mar 13, 2016 | 04:32 PM
DTA4's Avatar
DTA4
Default Battery
Put a new battery in car last week/ Went this morning to give my son a ride started right up and took him for a ride. Parked in driveway for about 30 minutes went to start and dead. Put charge on it for an hour and still nothing. Other than being a bad battery any ideas?
Old Mar 13, 2016 | 05:54 PM
DTA4's Avatar
DTA4
The thing that has me baffled is started right up after sitting for a week and ran great. After putting on charger for an hour voltage on charger was still showing zero. If the new battery I bought brand new was bad would it start at all like it did this morning?
Old Mar 13, 2016 | 09:45 PM
mrlmd's Avatar
mrlmd
Did you ever check to see if your battery connections are clean and tight?
Old Mar 14, 2016 | 09:29 PM
DTA4's Avatar
DTA4
So today just charged the battery and when I hooked it up and started right up. Week ago I cleaned the inside and had doors opened for a bit. Any other suggestions?
Old Mar 15, 2016 | 03:32 PM
gilbos440rt's Avatar
gilbos440rt
Think I'd have it load tested, a bad cell is uncommon but can happen even in a new battery sad to say
Old Mar 15, 2016 | 03:56 PM
Get the battery tested and see if you happened to get a bad one.
Old Mar 15, 2016 | 05:20 PM
Rexde1's Avatar
Rexde1
I had the same problem and it turned out to be the starter. I have also had brand new batteries that were bad.
To Battery
