Mechanical issue- 1998
Old Mar 13, 2016 | 05:30 PM
dk090304's Avatar
dk090304
3rd Gear
Default Mechanical issue- 1998
I had the window motor replaced since my window wouldn't go up and down. After it was replaced it started causing issues where the electrical would totally shut down. Motor replaced again and same thing. I got stranded numerous times. Now window won't go down again and same issues. Help!
Old Mar 14, 2016 | 12:11 AM
CactusCat's Avatar
CactusCat
First thing is to pull your codes and see what's happening. After pulling the codes, report back here with what you've found. Just on a hunch, check your connections in the accordian tubes in the doors (by the door hinges). They're well known to have issues. Here's how to pull the codes.
Old Mar 14, 2016 | 07:11 AM
dadaroo's Avatar
dadaroo
What does "where the electrical would totally shut down" mean????????????? And, how did you resolve it?????
Mr. Sam
To Mechanical issue- 1998
