nut for dash vent cover?
Thanks.
Maybe what I think is a nut is a sensor? Should they be black on each end of vent cover?
So I can just pull up the cover?
Thanks.
And yes both are black. or have a black cover on them.
The sensors are for Twilight Sentinel and for Sun Load Sensor.
Second, the grill is just a press fit into it's opening and NO screws are used. Just pry up on the OUTER frame of the grill and it will easily come right up. DO NOT use the thin grill slots to pry on, as you WILL crack one. They are delicate. If you don't have a plastic trim removal tool already, then use a credit card as a lever to pry with. Again, DO NOT pry on, or force the grill bars themselves. Pry ONLY on the outer frame.
Once you get the grill up a little and out of the dash a bit, there will be either one or two sensors still attached to the grill with pigtails that go down into and behind the dash pad. Each of the sensors are of a "Insert-in-the-hole-and-twist" type of installation (some call it a "bayonet lock type design). Should be 1/4-turn to release it.
Caution: after releasing the sensor, be careful to not let it fall back down into the hole. I would advise having some tape ready (maybe 4" or 5") and wrap it around the pigtail to prevent it from dropping down behind the dash.
HTH
