No more plastic jack pucks!
Old Mar 22, 2016 | 02:51 PM
knewblewkorvette's Avatar
knewblewkorvette
I have these on both my 98 and 02. Much cheaper than Elite's.
I actually have two sets on my 02 to protect the lighting underneath the car.
http://www.aacorvette.com/performanc...products_id=90
Old Mar 22, 2016 | 02:53 PM
cadwiz_01Z's Avatar
cadwiz_01Z
Veteran: Marine Corps
From: When Democracy becomes tyranny, the armed citizens will still get to vote!
Originally Posted by thisMSGgood4me
A jack like the one you pictured should work fine without pucks. The lifting pad of the jack is small and flat and should fit well within the area inside the rocker panels so as not to damage them. Many of us use floor jacks that have larger, round lifting pads that need pucks to give them sufficient clearance to prevent crushing an edge of the rocker panel.
Also, the places that change tires use floor-jacks as well. Gotta make sure they use the pucks or you'll be sorry.
Old Mar 22, 2016 | 07:34 PM
Crosis's Avatar
Crosis
Originally Posted by rrwirsi
The only problem is if you do not live in the cold area of the country where ice hockey is played, the pucks are not available at the sport shops. Need to order them on line. Minimal shipping cost from 'Dicks'.
Hockey is played pretty much everywhere. I am in florida and can find pucks in every sport shop.
Old Mar 22, 2016 | 07:42 PM
SG Lou's Avatar
SG Lou
Originally Posted by striper
Hockey pucks work great and don't break. You can drill a hole and put a bolt through the center to keep aligned and in place. Total investment under $10.
Yup, Home made Hockey Pucks...can't go wrong
Old Mar 22, 2016 | 09:15 PM
TrackAire's Avatar
TrackAire
Originally Posted by craig_vette
Are jackpoints recessed on all C5s? My 2000 FRC worked just fine when I jacked it last weekend. I just made sure I cleared the body panel. Mind you, i didn't use a floor jack, just a generic jack like the one below.
These are exactly what I use. Picked up four of them at Wally World and threw the crank handle away and use a rechargeable drill with a 15/16" socket. I can lift all four tires off the ground in under 5 minutes without even breaking a sweat. I liked them so much I bought 4 more to keep in the race trailer for use at the track.
These are super low profile and you don't need any sort of pucks....for around $25.00 each they are hard to beat (especially for lazy dudes like me, lol)
Old Mar 24, 2016 | 07:54 PM
TyGuy's Avatar
TyGuy
Jim993- Thanks for sharing this info!
I too use the "leave-in-pace" plastic jacking pucks. While I've not experienced what you did, I did break 1 on initial install trying to seat it against a homemade rubber gasket (used to keep them tight in the slot.)
I should've canned em then, but now I have to b/c the recesses on the new frame savers/sliders I got don't fit around the plastic pucks.
Considering the hockey puck route now.
Old Mar 24, 2016 | 08:02 PM
jackthelad's Avatar
jackthelad
I have a traditional heavy duty floor jack with a removable pad, with a machined metal adapter which replaces the pad, designed to fit into the slot in the chassis jacking points. Once in place, nothing can move. Does the job nicely, but since I lowered the car a little, I now have to run it up on some scrap 2x lumber to get the jack under.
Old Mar 24, 2016 | 08:37 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
I wrote this back in 2010 it became part of the DIY Sticky in the C5 Tech Sticky section, post #85
https://www.corvetteforum.com/forums...ck-thread.html
They have worked well for me but I would see the aluminum ones as an added safety factor. Though ultimately I want to install a MaxJax 2 post lift in my garage.
Old Mar 24, 2016 | 08:42 PM
Kj814fun's Avatar
Kj814fun
Old Mar 24, 2016 | 09:24 PM
SG Lou's Avatar
SG Lou
Once you go Hockey Puck you never go back........
Old Mar 24, 2016 | 11:58 PM
jim993's Avatar
jim993
These look like the one that caused the problem. I never left them in, only put them in when I wanted to raise the car.
http://www.ecklerscorvette.com/corve...1997-2012.html
Got the new (used) wheel well panel yesterday, just put it in. All is right with the world.
Old Mar 25, 2016 | 09:19 AM
Clancy209's Avatar
Clancy209
I use hockey pucks drill through center and then I use a butterfly anchor to hold all in place does not come out.
Old Mar 25, 2016 | 10:05 AM
  #33
huesmann's Avatar
huesmann
So, the question becomes: unless you're also placing your car on jackstands at the jacking points, why do you need 4 jacking pucks?
Old Mar 25, 2016 | 10:15 AM
  #34
Gordy M's Avatar
Gordy M
15 years ago, there was thread using BMW hard rubber jacking puck. They snapped into place at the jacking points. I purchased 4 of them and left them...they have been in place ever since. Since then I have gone through 3 different floor jacks--autocrossing, hpde, time trials, etc. Also I have gone from Hoosiers to street tires, changed oil, trans, clutch, suspension etc. and the jacking pucks look good as new.
As I recall they came from an E36 BMW and with the BMW tax were about $24.00.
Old Mar 25, 2016 | 01:57 PM
  #35
pologreen91's Avatar
pologreen91
If you decide you don't want to make any and would rather have metal I picked up a set last week from supporting vendor Southern Car Parts. They had the Billets on sale for $54.95. Shipped quickly no issues.
Old Mar 25, 2016 | 07:02 PM
  #36
jakecol's Avatar
jakecol
Originally Posted by akapounder
started a new thread for the ramps, can't get Power Point to load however !!!
Please keep trying about details. I'm very interested.
Old Mar 25, 2016 | 07:07 PM
  #37
Pounder's Avatar
Pounder
1/4 mile/AutoX
To No more plastic jack pucks!
Old Mar 25, 2016 | 07:14 PM
  #38
jakecol's Avatar
jakecol
Interested concerning your ramp set-up.
Old Mar 25, 2016 | 07:18 PM
  #39
Pounder's Avatar
Pounder
1/4 mile/AutoX
You need more than this, download both files !!!!
https://www.corvetteforum.com/forums...991-ramps.html
Old Mar 25, 2016 | 08:43 PM
  #40
jakecol's Avatar
jakecol
Thanks much.
