Tips on changing DRL bulbs?
Apr 3, 2016 | 01:27 PM
St. Jude Donor '13 thru '26
My hands are too big so going through the brake duct vent is not an option. My minions aren't home either so I can't use their little hands?
Apr 3, 2016 | 01:35 PM
St.. Jude Donor '17-'18
I think I've read somewhere that removing the hood stops made it easier, never tried it myself as my hands can squeeze in the duct vents.
Apr 3, 2016 | 01:45 PM
Remove the headlight bezels (3 screws) and the hood support bumpers as noted above. You'll be able to reach right down to the top of the corner light housing . The DRL bulbs mount from the top. The socket holder has a spring lock, just squeeze it with your fingers and turn the bulb socket.
Apr 3, 2016 | 01:46 PM
If all else fails, take off the access panels under the front fascia and you have full access to the back of the light housings.
Apr 3, 2016 | 01:56 PM
Most sockets become brittle and overheated from the stock lamps. Why not drop in some switchback led's and a hyperflash harness...They should last a lifetime, look better and will save your sockets unless it's too late.
Apr 3, 2016 | 02:05 PM
Got em!!
Took out headlight bezels and hood support bumpers!!
BTW - They are LED's with the hyperflash harness!
Thanks for the help guys!!
Apr 3, 2016 | 10:33 PM
St. Jude Donor '16
Quote:
Originally Posted by
jptgs1
I think pouder has some minions for ya!!!
Apr 3, 2016 | 10:49 PM
I just did mine yesterday...removed about 6 screws and there it was...
Apr 3, 2016 | 10:54 PM
jdvann
Something tells me you might have been laying on the floor/ground? I had a white shirt on!
Apr 3, 2016 | 11:11 PM
jptgs1
Yeah I had plenty of room.
Apr 3, 2016 | 11:17 PM
jdvann
I need some of those ramps in my life. Is there a lot to building them?
Apr 3, 2016 | 11:21 PM
001pewter
I used Pounders plans as a guide and tweaked a little. See link to Pounders post below.
https://www.corvetteforum.com/forums...991-ramps.html
I had to extend my ramps because my car was lowered...my wife's car is 1/2" higher than mine, had no problem with the 77" ramps but I made extensions for my lowered car...
Apr 3, 2016 | 11:31 PM
jdvann
I'll give it a shot after my ankle heals. Thanks for the link.
