I have been experiencing a slow leak on my left front tire for the past 2 months. Every time I'd fill it to 30 psi in a matter of 2 weeks it would leak down again to about 23 to 25 psi. I couldn't find anything in the tread area so I figured i'd have to take it to the shop. So like a dope, I'm standing at the front of the car staring at the wheel and then it hit me.
Got a 1/4 " drive deep socket ( can't remember size) and checked the TPM nut. I was able to get a full turn and a half on it before it snugged up. While i was at it I checked the rest of the wheels. I was able to pull up on the rest anywhere from a 1/2 to 3/4 of a turn before they got snug.
Left front tire has been holding pressure !
I dunno if this was just a fluke or what but from now one I'll make it a point to check them at least twice a year
I'm not sure what your source is for the specs for '01 - '04 but my FSM says 35 lb in for domestic vehicles and 106 lb in for export vehicles (page 3-111 of the '02 FSM).
I have read that there are differences between the printed manuals and the dealer's electronic ones. The dealer's show 62. I have also read that there was a service bulletin that changed the spec from 35 to 62. I took a brief look though and could not find the bulletin. I will update if I find it.
The Schrader (OEM manufacturer) spec for torque is 62. This might be confusing because the Scrader spec for the early sensors is also 62, but I don't know if they changed the oring to a formed gasket on the aftermarket sensors so the early and late torques might be the same now for Schrader aftermarket. Some of the pictures of new early style Schrader appear to have the later seal.
The export vehicles used the early style sensors so the 106 matches to the early sensors.
Yes, that is confusing. Please let us know if you come across that bulletin you referenced.
All I can say is, when my new tires and sensors were mounted, I told the tire guy to use 35 lb in and mine haven't leaked yet. It's been probably a year or more so I might just try and see if they're still at that spec, and if not bring them up to at least 35 lb in. I don't want to take a chance of over-torqueing them, and as long as they're not leaking, all should be good (as far as I'm concerned).
I got to get me an Inch Pound Torque Wrench
1/4" or 3/8" drive or both ?
Depends on how much torque you need to apply. 1/4" drive wrench generally has a lower range of torque settings than that of a 3/8" drive wrench. Also depends on what drive size your sockets are (if you already have a set and don't want to buy another set).
Just to throw my $0.02 in on the torque value. In reality, you need the nut to apply enough force to adequately seal the valve stem, you not enough to damage the seal or the sensor. You also need the nut to have enough torque applied to it so it remains tight.
IMHO, a minimum level of torque, so the seal doesn't distort, but a drop of blue Loctite on the threads, so the nut remains tight, will work well.
Well I snugged then down and I'm keeping an eye on them. It's been 5 days since I did it and it's still holding the pressure. I'll continue monitoring it and if it loosens up again I'm add a drop of Blue to it !
Lou, if you choose to do that, just be VERY careful that the sensor doesn't drop into the wheel, while the nut is off. I can't remember why, but I had to do something with the sensor nuts on my wife's car, a couple of years ago, and I didn't want to break down the tires in order to do it.
I took the wheels were off the car, however, and I set the wheels on my workbench, upside down, oriented so the sensors were hanging over the edge of the bench, and fortunately, gravity held them in place, while I R&Red the nuts. I was very careful, however, not to push on the stems, while the nuts were off.
