Refresh my memory
Old Apr 10, 2016 | 08:35 PM
Vanover's Avatar
Vanover
Default Refresh my memory
Can somebody refresh me on how to retrain my tire pres.sensors.
Old Apr 10, 2016 | 08:47 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
This should help!
Old Apr 10, 2016 | 09:02 PM
Vanover's Avatar
Vanover
Originally Posted by jptgs1
Thanks,just did it.everything works good now.ive done it before ,just forgot how.thanks for the refresher
Old Apr 10, 2016 | 09:08 PM
Jeff T.'s Avatar
Jeff T.
Check that off the "to-do" list!
Old Apr 10, 2016 | 09:10 PM
Vanover's Avatar
Vanover
That's right,but I'm sure I'll forget again. thanks for the help
Old Apr 10, 2016 | 10:09 PM
JR-01's Avatar
JR-01
Print this out and put a copy in your owners manual.
C5:
Reprogramming the sensors requires a strong (preferably u-shaped or circular) magnet.
1. Turn the key to the ON position but do not start the car.
2. Press the DIC RESET button to clear any warning messages, if they’re present.
3. Press the OPTIONS button and cycle through the menu until the display goes blank.
4. Press and hold the RESET button until “FOB TRAINING” appears on the display.
5. Press the OPTIONS button once. A “TIRE TRAINING” message is displayed.
6. Press the RESET button once. A “LEARN LEFT FRONT TIRE” message is displayed.
7. Hold a magnet over the Valve Stem on left front wheel. You may have to move it around the valve stem to hit the right spot.
8. When the horn beeps (about 7 seconds later), programming is complete for THAT wheel.
9. Program the other 3 wheel sensors as directed by the DIC message display. The sequence is as follows: Left Front, Right Front, Right Rear, Left Rear.
You have approximately 45 seconds to train each tire. If the sensor isn’t reset in that time, the training program shuts down and you will have to start the entire procedure over.
Old Apr 10, 2016 | 11:46 PM
- good advice.
Old Apr 11, 2016 | 09:43 AM
JR-01's Avatar
JR-01
Print this out too and also put it in your owners manual.
How to Pull Codes:
1. Turn your key to the "ON" position, but do not start the engine.
2. Clear any present messages by pressing the RESET button.
3. Hold the OPTIONS button down, and press the FUEL button 4 times. (This will get you into the "codes" section of the DIC.
4. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. (Have a pen and paper handy to write down the codes)
Note: Any code that ends in an "H" is a history code (something that has occurred in the past, but is not reporting as an error currently.)
5. Once the computer has finished going through all of its codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# Codes."
6. To optionally reset codes once in manual mode, press and hold RESET until is displays "NO CODES."
7. Press OPTIONS to go into the next module (ie, from PCM, or Powertrain Control Module, to TCS, or Traction Control System.)
8. Repeat Step 6 until you have reset all the codes in all the computer modules.
Note: Only reset the codes if you want to- it is not necessary to reset them every time you pull the codes.
9. When finished, simply take your key out of the ignition.
Old Apr 11, 2016 | 12:55 PM
mrlmd's Avatar
mrlmd
Don't forget - when you get new tires and decide to get new sensors, train them first before mounting them in the wheel then mounting the tire on, just to be sure they work.
To Refresh my memory
