Shift knob help
Old Apr 24, 2016 | 05:08 PM
rrwirsi's Avatar
rrwirsi
Default Shift **** help
I am trying to remove the mod shift **** (see pics) from my stock C5 sifter so I can replace with the original. There is no outside access port such as an allen wrench bolt holding it on. I have tried everything but it does not budge. Note there is a Corvette logo on the top of the ****. The top appears to be a cap but numerous attempt to pop it off have not worked.
So, just wondering, is there anyone out there in the CF5 world that has a **** like this? If so, how is it removed? Thanks
Old Apr 24, 2016 | 05:12 PM
dbgoodwin's Avatar
dbgoodwin
Maybe a wife or daughter with stronger hands than you can give it a shot?
How certain are you that its a stock shifter? I've also seen some people epoxy the ***** on for no apparent reason....
Old Apr 24, 2016 | 05:16 PM
rrwirsi's Avatar
rrwirsi
Removed the boot and looked at the shifter. It is stock. I had a neighbor that can bench press a zillion pounds and my go to mechanic try and they could not twist either way. My fear it is on with epoxy
Old Apr 24, 2016 | 05:30 PM
dbgoodwin's Avatar
dbgoodwin
Ah, there's your problem. Find a 35 year old virgin and I promise you he can get it off. (The ****, that is)
Old Apr 24, 2016 | 06:55 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I have never seen that shift **** before but did you try to remove the cap? Maybe it installs like the OEM **** and there is a demon key underneath.
Old Apr 24, 2016 | 07:19 PM
Hotrodzz3's Avatar
Hotrodzz3
Might have been installed with loc-tite, try heating with heat gun or hair dryer.
Old Apr 24, 2016 | 07:41 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
That was my thought as well.
Old Apr 24, 2016 | 08:08 PM
rrwirsi's Avatar
rrwirsi
Yep, there seems to be a ridge a the bottom of the cap and I tried with every sharp tool I could think of. No luck.
Will try the hair dryer method. Did not think of that. Will post results.
Old Apr 24, 2016 | 09:53 PM
Pat Tucceri's Avatar
Pat Tucceri
Old Apr 24, 2016 | 10:26 PM
chasboy's Avatar
chasboy
Oldtimer
Can you get a GOOD view of the bottom of the ****? You might find some telltale key to how it's held on. If you have no love for the ****, that top cap would either pry off or be drilled thru.
Old Apr 25, 2016 | 08:08 AM
rrwirsi's Avatar
rrwirsi
Yes, I did pull down the boot cover and could not find anything that would show how this #$%# thing in on. Still hoping somewhere in CF world someone has put this **** on their Vette.
Thanks all for your help.
Old Apr 30, 2016 | 05:05 PM
rrwirsi's Avatar
rrwirsi
Update on removing the shift ****. I put a high heat hair dryer on the shift **** for about 30 minutes. I was hot, very hot. Still no budge in the ****. So, either forget taking it off or cut it off Need some time to decide.
Old Apr 30, 2016 | 05:14 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Time for a shifter upgrade?
Old Apr 30, 2016 | 08:06 PM
Frank4202's Avatar
Frank4202
To me, it looks like either the center cap pops off or ONLY the black top piece spins.
Old Apr 30, 2016 | 08:14 PM
Vanover's Avatar
Vanover
Done the centre cap possibly screw on the ****
Old May 1, 2016 | 01:28 AM
chasboy's Avatar
chasboy
Oldtimer
Drill out the center cap. This thing is toast no matter what.
Old May 1, 2016 | 09:38 AM
rrwirsi's Avatar
rrwirsi
That is what I thought. I tried every sharp item in the kitchen and my tool boxes to pop the top cap off and nothing happens. Then I took a magnifying glass and looked at the bottom edge of the cap and it appears not to be a separate piece from the black neck. I also thought the black hard rubber neck was the answer. I used vise grips on it and the shaft and it did not budge. I believe the idiot who put this *** on used an adhesive on the threads that unfortunately did its job too good!
So I am at the point to decide whether to leave it, cut it off, or as 'Shifter suggest, get a new shifter.
Thanks everyone for your help and suggestions.
To Shift knob help
Old May 1, 2016 | 04:47 PM
chasboy's Avatar
chasboy
Oldtimer
If you have one of those oscillating tools that are popular now, with a metal blade, cut thru the thing VERTICALLY so you can pry it off without damaging the shaft. Otherwise, use a hacksaw, be careful and don't slip. Also a Sabre saw with a metal cutting blade would work, just more vibration and dust.
Old May 4, 2016 | 05:26 PM
mpride's Avatar
mpride
Is it possible that the bottom metal portion of the **** either screws on to the upper portion of the know or pulls down from it revealing how its attached?
Old May 5, 2016 | 09:39 AM
rrwirsi's Avatar
rrwirsi
I removed the boot from the consul and found remnants of glue on the underside of the boot. So, yes, this **** is most likely screwed on and then the idiot that put it on used glue on the threads. I tried heat from a hair dryer but did not get the **** hot enough. I bought a heat gun and will try that. Stay tuned.
